Under cabinet LED conversion help!
Jim_No_Garage
Millington NJ
Hello - in 2001 we had our kitchen and attached pantry redone with new everything. At that time they installed mini t-8 fluorescent lights as under-cabinet lighting. The cabinet lights in each room individual rooms are hard wired to a switch across the room.
The fixtures go thru bulbs pretty quickly so I want to convert to LED's. I want to put in LED "tape" lighting but am having trouble finding a transformer. I want a hard-wired transformer not a plug-in transformer but can't seem to find one.
I just found this on Amazon but the ONLY reference I can find to this MFG is Amazon itself or a bunch of defunct blog entries. That's a bit scary . . .
http://www.amazon.com/gp/product/B00PXNIO34/ref=od_aui_detailpages00?ie=UTF8&psc=1
It indicates that it's UL listed - would you install this in your kitchen?
The cabinets are to the ceiling, so I can't hide an outlet and plug in transformer above the cabinet and I don't want them IN the cabinet.
I might have to trace the 120V wiring and see if I can tap into it in the attic. But then is it a good idea to have a transformer in the attic?
Cheers
Jim
rsanter
visalia ca
Look up LED tape or strip
Ere are websites that well the rolls of the tape and they have the matching driver/transformers as well
Bob
OJ Bartley
Toronto, ON
Jim, in our kitchen I used LEDs and a transformer from http://www.flexfireleds.com/.
We used a double strip of the Ultrabright Design Series, because that's what a full reel worked out to cover under the cabinets we have. The power comes from a 100w (I think) Zurik dimmable power supply, located in the basement just below the kitchen. Low voltage wire back up through the wall to the cabinets. It is controlled by a Lutron dimmer, and works great. Doesn't dim right to zero, but pretty close, minimal flicker at very low levels. When at 100% it is very bright, I usually leave the dimmer around 75%. I probably would have been totally fine with a single strip.
Actually, here you go, they put some pics of my project up on their blog: http://blog.flexfireleds.com/install-cabinet-led-strip-lighting/
Hope that helps.
J
Jim_No_Garage
Millington NJ
Hope that helps.
OJ - thanks for the reference. I'm trying to NOT have to run new wiring as the kitchen is finished with a partially finished (drop ceiling) basement below. That said - the best solution is to go with what you are proposing - I will have to think about that.
I ordered one of those transformers and a 15' reel of warm white LED's off of Amazon. We shall see how the quality of the transformer is.
Cheers
Jim
cybrdyke
USA
Pick your tape first, then get an appropriate driver....not the other way around.
Good luck.
CD
