Under cabinet vent
55stone
Good morning guys, I’m redoing my kitchen and have 2 vents under my cabinets. There was nothing really there before just a vent in the toe kick with the heat filling the area up below the cabinet. I was wondering what you guys do for this. I saw the kit from the toe ductor but 70-80 bucks a kit seems crazy. I looked at menards for pieces to make something similar myself but couldn’t really come up with anything.. thanks for any help!!
b-boy
Buffalo NY
I have this same setup in my bathroom. There is a blower that kicks on/off based on a thermostat somewhere. I have no idea where the thermostat is (I assume it's in the blower), what it's set to, or how to change it. There's a wall switch to provide power during the Winter. It works, but it doesn't provide a ton of heat, and it's noisy as hell.
I'm looking for alternatives when I remodel.
55stone
brewcheif. i saw those.. does it stick down into the current piece that is in the floor?? i dont believe they had the size i needed either. the vent piece in the floor is 4"x12"
55stone
i totally didnt understand this piece till looking at it again. its design for the oval portion to go into the floor. i was looking at it the other way. wow im an idiot lol..
The Cobbler
you can use a pc of 3-1/4x10 duct under the cabinet, cut into the toe kick . close the one end off. cut a hole thru the subfloor , put a pc of 5" round into a hole cut into the duct or use a fish lock collar . 3-/4 x10 floor vent is a standard size
Kaizen
New England
Two different setups discussed above. Kickspace heater and just an outlet for hvac. That location is better then the floor that will fill with dirt when sweeping.
