Attached are pics of ceiling after I raised it 14". It didn't occur to me at the time to add vapor barrier before we reinstalled the ceiling with 5/8" drywall. BTW, the new joists are 2x12 and the ceiling is already finished.
Now I'm finally planning to adding insulation to a section of my garage that will be heated. I'm putting up a dividing wall and will be heating the section on the left in the crude attached image. The bosses side is on the right and adjacent to the house and will remain unheated.
The insulation will go in from above like a typical attic insulation job but I only see a few options for adding vapor barrier from the top:
1. 6 mil poly stabled and taped in each bay cavity. - Not expensive but a hassle given the bay is ~25 ft. long
2. Adding rigid foam that's sealed around the edges to each cavity like this: https://www.nrcan.gc.ca/sites/www.nrcan.gc.ca/files/images/enerpedia/figure_5-10_5.jpg but it's an added expense I would prefer to avoid.
3. I've seen where poly is sealed on top of the joist: https://www.nrcan.gc.ca/sites/www.nrcan.gc.ca/files/images/enerpedia/figure_5-9_0.jpg All insulation will be in the cavity and not on top of the joist as it has a floor and the atic area is used for light storage.
I'm not aware of any other solutions from above to add a vapor barrier.
I'm leaning toward unfaced R30 rolls in the cavity (which is very economical compared to faced batts or rolls) and painting the ceiling with a vapor barrier paint. This seems check all the boxes: ease of work, cost, effective.
Any thoughts on this approach?
