Unsticking a Wilton - Fail
paulsomlo
Northern Colorado
I had the vise upright on my HF 20t press, 1" solid rod between the two jaws resting on aluminum yokes, as shown. I had the yokes blocked from the front to keep the vise from sliding and had a bottle jack horizontal between the press upright and the base of the vise to keep the base vertical. The aluminum disk was interposed between the ram of the press and the back end dynamic jaw. Apparently, the upright bowed with the result as shown - now I have to figure out how to unstick the beam of the press, which got lodged in there pretty good when things let loose. And I've still got a vise that's stuck - doesn't seem to be any rust, just dried up grease.
RoninB4
Under My House
-If it's the horizontal beam (two C channels) stuck against the box section I'd try knocking the shaft though the box section. There's less contact patch on the shaft.
-For the vise, looks like a job for a Kroil soak. Good luck. Repot, when you can, what caused the vise to stick so badly.
-Not a fail, this ain't over yet...
senlow
Wheat Ridge, Colorado
Carefully spread the columns with a porta-power and you should be able to move the beam back in place.
I agree with Ron on the vise. Soak it in penetrating fluid. Don't rush the process. Be sure to let it soak for several days. Some heat should be helpful.
P
paulsomlo
Northern Colorado
I've tried soaking with Kroil and WD-40 from both ends for days/weeks - I've been working on this on and off for a long time. I think it's so bound up that the penetrant just can't make much headway. As far as heat, it's gonna take oxy acetylene with a rosebud, which will destroy the original paint, which would be nice to retain.
I gave the shaft through the box section a couple of wacks, didn't seem to move much.
I'll report back when I've made some progress.
LopezBart
Lopez Island, WA
You might try using some of that citric acid based rust remover left to soak in the seam...
If you have some dry ice, combined w/ acetone it makes for powerful cooling bath and soaking the back end of the vice may help loosen things up...
larry_g
oregon
On the press, can you release the horizontal brace that is near the floor to let the columns spread apart?
On the vise, if you have some separation on the jaws run a piece of allthread through the center and pull the jaws together to get some motion going.
lg
RoninB4
Under My House
-When rust in involved it's a **** shoot whether moving components are now integral. We had a dinner table size injection mold that was seized from improper storage, couldn't get the halves to split. Foreman took to soaking the pins and slides in Kroil, minimal clearance between pins/bushings was also difficult for penetration. Once a week he'd suspend one half the mold, allowing the other half subject to gravity. Then he'd begin "therapy" with a heavy rawhide mallet for a few minutes before re-oiling and putting the mold away for next week. This went on for many weeks and I even gave up hope that it was going to separate. It molded tail lenses for 54 Fords and was too expensive to make a new mold. After about a month or two of mallet therapy it dropped the gravity half, I was amazed.
-May I presume that you're trying to move the slide in two directions or just one? Much like removing a stubborn bolt it sometimes helps to move/rotate in two directions to scrub off some of the rust/oxidation to "unlock" it.
-Well phooey. Where does it appear to be contact locking?
-Good luck to you.
P
paulsomlo
Northern Colorado
I don't believe that it's rust that's holding it - I think it's a vice with very little wear, thus a tight fit, and dried up grease.
P
paulsomlo
Northern Colorado
lg
Nope - the bottom brace is welded.
I did that initially; I was able to fully close the jaws, because the geometry of doing so on the press favored it. But it didn't seem to break anything loose.
whateg01
doo dah, kansas, usa
You should know this now, but this is a weakness in the design of many hydraulic presses. Better ones will have a way of preventing the splaying of the columns. As an operator, you should be watching everything for movement. Many a stained-pants moment has resulted from something moving or breaking suddenly and a large part under a lot of force suddenly flying out of the press.
You'll have to spread the columns somehow. A portapower has been suggested. You might be able to use a bottle Jack or even a floor jack if held in the correct orientation. Those aren't going to be stable operations though, so again something could come shooting out of place. Once you get it unstuck, you need to figure out how to straighten the column or it will be even more likely to happen again in the future. I suggest welding a small piece of metal on the bottom of the bed so that the pins are trapped and can't get out of position. Done by notching in this pic, but you get the idea. Or add a strap around the ends of the bed so the column is trapped.
P
paulsomlo
Northern Colorado
-Good luck to you.
I'm only trying to move the slide axially, no rotation - that's hampered by the key. And given that having closed the jaws on the press initially didn't break anything free, I'm not sure that rotation would help.
I was able to knock the press pin out of one side, then it angled and stuck on the other side. I tried a crowbar on the inside of the upright - it slipped and wacked my thumb pretty good. After some ice and an ibuprofen, I'm almost ready to tackle it again.
I know one thing - me and this crappy Harbor Freight shop press are most likely parting ways. It's frustrated me for a long time and I don't need tools that elicit obscenities from me.
P
paulsomlo
Northern Colorado
I played with a bottle jack and some metal rods, even a 2x4, but trying to hold all that with one hand and pump the bottle jack with the other proved too cumbersome. Maybe with the entire frame on it's side?
The pin didn't become disengaged - what I think happened, is that the bed slid all the way to one side and then the column bent.
Shiftless
East Bay SFO
Do you know anybody with an induction stove?
That would heat the entire vise very evenly and melt any old grease. If you’re careful, it shouldn’t get hot enough to destroy the paint.
How about this plan?
1. Fix old press or get a new one
2. Heat the vise on induction stove
3. Using hot pads and thick gloves, move vise to the press.
4. Apply force with the previous set up.
edit: While it is hot, squirt in more penetrating oil before pressing.
Long ago, I had a 4 inch Wilton bullet machinist vise that was badly stuck. No apparent rust. I struggled greatly and finally got it to move and saw just a small ring of rust inside that was the cause of the problem.
Good luck with your project. Keep us posted… we are cheering for you. 🍻
alfadan
Augusta, ks
I wonder if driving a wedge between the jaws with steady pressure in the press while supporting the jaw from beneath would work. As in, putting pressure on the wedge overnight, or over a few days.
whateg01
Regardless which thing moved, in practice the bed moves to the side but more importantly, it flexes, which gives it very slight wedge shape which pushes outward on the pin, which, since it's in a hole in the column, pushes outward on the column which means the pin is no longer supporting the bed. Hence it is no longer engaged with the bed. The point is, forcing the pin to stay under the bed prevents that whole chain of events from happening. Or just leave it like it is and take your chances. What's
P
paulsomlo
Northern Colorado
The beast has been slain - one of them, anyway. I removed the bottle jack, took the frame outside, laid it on it's side and gave the bed a few wacks with a deadblow. I'll move this thing to the garage, as I really don't have the shop space for it anyway and it's taking up valuable real estate, given that I only use it a few times a year at most.
Shiftless
East Bay SFO
Idea #2
Change your set up to horizontal using a piece of steel or concrete against a solid wall as the “base”… the white board in your pic.
That way you could fabricate something that would lay right up against and pressing on the back of the slide and extend out a few inches,
With that set up you could swing a 10 pound sledge hammer against the back end and probably get some movement. Either a big sledge hammer or maybe even better… a demolition hammer. The vibrations might help. Either way, going violent might get you some success,
P
paulsomlo
Northern Colorado
Idea #2
I've thought about going horizontal with this; I did try clamping down the base and using a deadblow/metal rod on the back of the slide, but no go. I have thought maybe an SDS hammer drill on the backside?
danski0224
Near Naperville, IL
I had to remove an aluminum blower wheel from a steel motor shaft, and it barely came apart. There was a small spot of corrosion, maybe 3/8" around, that was the culprit. The shaft was 1.5" in diameter.
P
paulsomlo
Northern Colorado
This is testament to the tolerances to which these vices were made, I suppose.
danski0224
Near Naperville, IL
Doesn't take much. The identical setup above the problem child was a slip fit- the wheel just pulled off the motor shaft.
The other one only came apart after cutting the shaft (motor was junk), supporting the center of the aluminum fan assembly, and beating the shaft piece out with a 32oz dead blow hammer with a metal face, and a brass drift pin.
If the fan broke, we would have been effed, but the project manager did not listen to me and order a spare and bill it to the customer.
RoninB4
Under My House
-Yeah I only used "rotation" as an illustration of reversing direction to help break the lock. I wouldn't imagine the vise slide would rotate even when brand new.
-I've got one too and really don't like it either, never have.
-I refer to them as magic spells because I don't seem to get results until I've uttered one. Glad to hear you've battled your way back despite the collateral damage.
OccupantRJ
Eastern North Carolina
A bearing puller attached at the round area between the jaws coupled with two threaded rods and a cross bar at the rear of the vise may help. That is a direct line pull where needed.
whateg01
As long as that pressure isn't excessive. I would think applying pressure that way and then a good smack on the back might help just it loose. Somebody mentioned a demolition hammer.
P
paulsomlo
Northern Colorado
Ahh, yes - I tried switching end for end; I did get the vise to close, but now I can't open it back up. That's what makes me think that maybe it's not rust.
P
paulsomlo
Northern Colorado
I don't have a bearing puller large enough to get around the slide, and I'm dubious that one large enough would be up to the task without cracking. But, something improvised might be in order.
whateg01
Ok, I think we all thought it was just flat stuck. It moved then stopped moving means you need to stop trying to force it and figure out why it stopped moving. Undo that and it'll likely move again.
P
paulsomlo
Northern Colorado
Oh, it's stuck all right - it took a fair amount of force on the shop press to get it to close. The problem, is that closing it was a much easier process due to the geometry of things on the press. The fixturing for opening is much less forgiving.
RoninB4
Under My House
-Ok I'll ask the dumb questions. Back cap off and nut out? The vises I have (Reed, Prentiss, etc.) are different from the Wilton design. From the images below I don't see much to lock things up. By the description from @paulsomlo it doesn't sound like rust is the major factor here preventing movement. I'm wondering if the guide rail (#17) or the rail pins (#18) are ploughing the guide rail slot/groove? I've seen shaft keys get skewed/lifted (rust/debris or loose fit) enough to dig into the surrounding metal, making component removal difficult. Just one sharp/square edge starting to dig in can lead to further galling as more metal gets ploughed up. The result can lock up movement by compression or friction welding far more than one would think possible. I'm out of wild guesses here.
Shiftless
East Bay SFO
You show a diagram of a Wilton “bullet” machinist vise. Look again at the picture in the first post. The one Paulsomlo is working on is NOT a bullet and is more like the vises you mentioned… Reed, Prentiss etc.
If the slide is a bit bent or deformed, it can wedge itself pretty tightly into the vise body. I bet that is what happened to the vise in question.
Mike007
This seems to fit with the scenario. I can't imagine the force required to bend the slide. When this gets resolved the answer will be interesting.
RoninB4
Under My House
-The images were used because it showed the exploded diagram and cross section of a round slide vise from Wilton. The vise in question from the OP appears to be a round slide like a Tradesman or Bullet. The info in the image below might help clear things up if you cross reference the numbers to the Wilton website. If it's not then perhaps you could post some info? I'll wait.
-Maybe yours are but neither of my vises are similar to the Wilton except in overall shape. Mine have square slides and the nut is entirely different in design and function. Do you own either of the models I have that supports your contention? Here's a link below
