Unused neutral lug
PoorOwner
CA
There is an unused lug similar to this in my GE panel under the row of breakers
Can I use it to ground one of the circuit?
This is main panel with neutral and ground tied
2DM13_AS01
sberry
Brethren, Michigan
I do it. If its good for a neutral which is a current carrying conductor which undergoes thermal it will likely be great on a wire that doesn't see use only rarely under a fault, to top that off most of these faults are rather limited, on current limited circuits.
Stuff
Under the breaker? Make sure that it is not one of two that would be hot pass-through lugs.
A picture of the panel would help.
P
PoorOwner
CA
It's under the rows and attached to the case, I am sure it is grounded but I will ohm it out.
I would like to add a ground bar at some point but I lost the sticker to the panel so I do not know which bar works for the panel.
Norcal
Buy a ground bar kit of the same make as the panel & it will fit.
P
PoorOwner
CA
Right now there is 2 white circle stickers that seems to be for a ground bar.. I assume that's where it screws in? Is there any bonding needed for the ground bar, I understand it's a ground bar and for grounding only, not neutrals
u3b3rg33k
+1 for pics. if it's not on a bus, just on the panel, i would be hesitant to pass current through it. it may ohm out low but still not be intended to handle current. pics needed.
