Pathfinder
Looking good. I love this thread. There is so much potential in this technology. Thanks for sharing!
John Minton
John Minton
John Minton
Thanks for the reply!
The piece I have in mind is what is called various names including torque tube bushing and bearing insulator. The part is used in 1961-1963 Pontiac Tempest driveshafts.
These cars have rear mounted transaxle transmission setups with motors in the car's front end. The drivershafts themselves are round shafts similar to torque tubes and they run inside a tunnel enclosure tube. The driveshafts are held in place within the tube by a couple of bearings that are held in place within the tube by rubber pieces that fit the contour of the tunnel.
The bearings are about 1 7/8" in diameter by 1/2" thick. The rubber pieces have a thin metal ring about the size of the bearing that is "vulcanized" to the rubber. The bearing is "pressed into this thin metal ring which acts as a bearing holder. It is these rubber pieces that are no longer available but there is a demand for them.
As I mentioned, there is a topic on this item in the Performance Years website forum which you may want to look into. The specific site is listed below and a picture of the piece is included in the thread.
http://forums.performanceyears.com/forums/showthread.php?t=745189&highlight=torque+tube+bushing
Looking forward from hearing from you.
Great thread, thanks for sharing your expertise! I can think of a few things I'd like to cast already.
Wow! I spent some time looking around smooth-on the other day and the range of different materials available is pretty amazing. I saw products that would let me cast clear lenses for lights, the obvious engine/suspension/subframe mounts, and even thin-walled parts like air ducts. The options really are limitless.The cool thing about this technology is the fact that imagination is the only limitation. The product lines offer more solutions than I can possibly scope.
Here's an example that blew me away when I began researching casting and mold making and it's just one of many.
http://www.smooth-on.com/gallery.php?galleryid=157
To be able to reproduce a record and have it play really speaks volumes about the fine detail it's possible to reproduce.
