Used Delta/Rockwell Floor Drill Press
GCLARK
I am having to sell my husbands tools. Please advise what available I should ask for the Delta Rockwell Floor Drill Press, 15" variable speed, 1/2 hp motor, tilting machinist table, with chuck
catalog # 15-665 serial #1444864 , very good shape. smooth no noises. not loose.
454ragtop
Carver, MA
Thinking the same as Jack. That's a pretty desirable model, with the large table and table raiser, pretty sure that's the 6 speed 6" quill travel model. GLWS
exmaxima1
Midwest
$250-350 in Chicago area
It's only a 1/2" chuck, and JT33 is not as desirable as a Morse spindle. Minimum speed is not likely below 400 rpm, so not really a heavy duty hole maker.
Whitworth
Some "for sale" venues in addition to Craigslist that may help.
Owwm.org
Woodnet.net
Bottlecapdigger
Ontario
Is that variable speed? I always seen delta drill presses with the adjustment hand wheel at the front. Where is it on this one? BCD
Kenwc
Speed on that model is made by moving the belt to different pulley positions.
Davefr
OR
I see:
- Single phase
- Table elevation (extremely desirable!!!)
- No arch of shame, machinist table
- Early (ie "better", Rockwell, "R" vs Peace symbol)
- Looks original
- Should clean up to look like new
- I'm also guessing it's geared for metalworking vs woodworking which makes it even more desirable.
That one's a "cream puff" IMHO and a very desirable model. I wouldn't take any less then $500 but prices tend to be regional. My guess is that So. CA tends to be on the high side.
I'd probably start at $750 and gradually reduce the price until it sells.
I agree that OWWM would be a great venue for selling this machine. Those guys will recognize the value of this fine machine vs. most of the CL crowd of lowballers.
P.S. I would encourage you to spend 30 minutes cleaning up the head of the DP with automotive cleaner/wax and clean the column and table with a scotch brite pad and WD40. I bet that would make it look like new.
