Used engine oil on the deck
andyvh1959
Green Bay WI
Member in my cycle club coats the wood on his deck with used motor oil. The wood sheds water, is a nice dark color once the oil sets in. Wood grain shows through, like a solid stain wood product.
Anyone else ever do this? How long it takes to not feel like oiled wood? Smell? Apply the oil straight up or thinned with mineral spirits? Any other issues? I'd assume once you apply oil to wood your only future options are either apply more motor oil, or maybe use an oil based stain product. Can't use any water based stain or paint, or the newer deck sealant/repair product. I'm asking because I have a small wood deck on the back of the house which gets a lot of sun aging.
Years ago I applied Behr Deck Over onto the then fresh, new treated deck wood, after I had let it season/dry for most of one summer. It looked good for a few years, but then started to blister and peel. That let the water (ice in the winter) into the wood surface. So now I need to either flip the boards over to get the unaged side up, or change over to some composite product.
LS6 Tommy
Northern NJ
I've been in a lot of old shops that had wood block floors with decades of oil spillage soaked into the blocks. I will say they all had a "oily" smell, especially shops that service trucks and heavy equipment (there's something about the smell of used differential lube that triggers many memories) but I can't say if it was the wood that smelled.
Tommy
Ralf11
used motor oil is toxic waste
any kids or reproductive women ever walk barefoot on the deck?
any vegetables grown near it?
I sure wouldn't tell the realtor if I were to sell the house either...
Lincoln33
Arkansas
I've never oiled a deck but I've considered using oil on wooden field posts. I've read other peoples comments on using oil on their trailer decks only to find out they're slippery when wet. I would imagine a house deck would be the same when wet.
Old Radar
San Antonio, TX
Succinct and to the point!!! Might as well smear it under your arms and gargle with it!
58Yeoman
Central IL
And I'll bet that member overhauls his bikes engine in the living room. I had a friend like that, die hard rider. He died at a young age about 2-3 years ago. Billy rode the HD until the roads got too slippery, then drove the VW bus I had sold him back in the 70's, until the roads were clear again. He still had the bus when he died.
Lassen Forge
We used to break used motor oil 50/50 with whatever light petrochemical we had handy (usually it was whatever was in the parts cleaner) and spray it on the dirt / gravel raod to keep the dust down...
I was told we can't do that any more due to the various anti-pollution laws... but it worked well for over 120 years on our back road... so we have 120 years of contaminant, and a county environmental health weenie saying now, the past 8 years, don't do it...
I get it... but I still think it's nuts...
Bigblockyeti
Upstate, SC
Aren't most women capable of being reproductive at some point?
A deck, I probably wouldn't do that, but on my trailer deck, absolutely. It's rough sawn so while it is a little slippery, it's not as bad as planed boards would be.
wade_660
I’ve always mixed used oil with stain to put on trailer decks. I did the deck on my house not long ago and only had new oil. I mixed 1qt per gallon of stain and it worked great. I actually like new oil better now. It is slippery at first but after one or two rains, it’s not slippery anymore. Same for the trailers.
MBfreak
MEMBER EMERITUS
Linkoping , Sweden
Great idea.
Up there with the municipality of a little place called Love Canal that got free transformer oil to spray on the gravel roads to keep the dust down.
Best regards
Ola
matt_i
I've used Thompsons Water Seal on my trailer which I've had since 2004.
Its about due
It beads water for a couple of years, the deck is still in good condition after 16 years of sitting outside, and it doesn't get slick....that would be a bad thing for me, I rely on the wooden deck to have friction with what I'm hauling.
A
andyvh1959
Green Bay WI
All good points, thanks. Not going to use the motor oil on the deck. I'll use some proper deck treatment for now until I someday replace the wood with a composite material. For now, the deck is small, and I need to take the deck boards off to do some drainage control underneath. So I'll flip the boards good side up for now and refinish.
Bretny
Dutchess county NY
If your going to take the deck boards up to flip them over..just flip them in the garbage and put on trex. Idk why people mess with PT decks anymore. Unless you heavily maintain them they look like **** in a few years and at least around here you will be lucky to get 10yrs out of one and have it look even half good.
homelessdespot
CT
If you have to keep spraying it, it's leeching into the ground. It probably leeched into ground water and into people's wells these years.
Boilerhouse
Muskoka
Motor oil for an exterior deck is not a good idea. i was actually down this road some years ago. The oil dries very slowly and is prone to picking up fungus spores, turning a new deck black.
Ralf11
I was wondering how to word it - I meant pregnant or lactating. Those are the stages most likely to damage a fetus/child with a toxic material.
ok, deck stain: I've tried a bunch (in the PNW) using samples about 15 types, and using 3 or 4 types on both horiz. & vertical pieces. The water-based ones are still ****, so if you don't have volatility regs. to deal with the best AFAIK is TWP or Armstrong - and SuperDeck is pretty close.
re: "overhauls his bikes engine in the living room"
In the interests of full disclosure and since the statute of limitations ran a few decades ago... I once overhauled and hotrodded a VW engine in the living room of my apt.
58Yeoman
Central IL
I'm sure Billy did the VW in his LR also. He had that van for at least 30 years. IIRC, it was a 66 camper van. I was dealing in VW rehab, and did a lot of them; can't remember them all.:lol_hitti
97tj-neil
PA
I built my deck in 2011 with PT deck boards. Stained it once the following spring, and again last summer. That is literally all the maintenance I have done. I just went out and took this pic after reading your post.
I suspect I will get much more than 10 years out of it.
In my opinion wood looks much better than any manufactured plastic decking and costs much less.
mike93lx
Richmond, VA
It amazes me the **** people do with stuff like this. I would never put used or new motor oil on a deck. The smell, the metals, detergents, etc. None of it was made for a deck.
Jazz1
Thunder Bay On.
Used motor oil,,,excellent...likely the same ilk that hook up tailpipe to blow hot exhaust under the mobile home to thaw frozen pipes
469 runner
North Carolina
I had a trailer with a wood deck. Used it to haul a riding mower that would drip oil. The sun would draw the oil up to the surface. Made a real mess. I don't know how putting oil on a deck would be a good idea.
58Yeoman
Central IL
DAMN! Why didn't I think of that? After my divorce, I bought a 10x50 mobile home and the pipes froze on me. I went out and bought a propane salamander heater and set it in the access door.
Years later, I dragged home an old Caddy and parked in the 2 car garage, to strip it of its' engine, etc. The mice came pouring out. The garage was separate from the house, so I started the Caddy and let it run for an hour or so, thinking the fumes would kill the mice. It didn't, but it sure did get warm in there.:lol_hitti
laser3kw
northen IL
there was a heavy construction outfit that would do that back where I grew up. County never objected because they also took care of the surrounding roads that lead to their site.
LS6 Tommy
Northern NJ
Love Canal was a landfilI with toxic waste chemicals. What you’re describing sounds more like Times Beach.
We had a class about historical hazardous waste dumping at one of my certification courses.
Times beach was Dioxin. The PCB transformer oil spraying was done by the Ward Transformer Company along side highways at night in NC. After they got caught and the "cleanup" was over, the NC EPA chose Warren County to dump the soil from the cleanup into landfills. Basically, they said it was a good spot because there weren't many residents and they were "Black and poor". Can you imagine if someone in government said something like that out loud today? :shocking:
Tommy
Old Radar
San Antonio, TX
Tommy
Sadly, yes I can. Only today instead of PCBs it's viruses and masks.
58Yeoman
Central IL
Many years ago in LaSalle, IL., there was a company that built transformers, called Electrical Utilities. Apparently, they emitted a lot of contaminants that contaminated many of the neighborhoods in the area. The company was closed and the EPA came in for a cleanup, and brought in a 'soil incinerator' to burn up all the dirt from the neighborhood yards. Most of the people got all new yards out of the deal.
After they were finished, the EPA shipped the incinerator to a small local paint company in my small town, where it was repainted and waited for the EPA to pick it up and take it to South America (IIRC). The EPA never came to get it, the painter never got paid, and it slowly just disappeared over the years.
Roadster J
Allentown, PA
Tommy
My recollection of Times Beach was contaminated waste oil being used as a dust palliative on gravel roads.
Thanks for clarifying that it was Dioxin and not PCBs.
Randy in Maine
The Beach
Times Beach (from Wiki) https://en.wikipedia.org/wiki/Times_Beach,_Missouri
This mess was generated from the improper disposal of Agent Orange that was poorly made and generated substantial dioxins.
Warren County Landfill PCBs (also from Wiki) https://en.wikipedia.org/wiki/Warren_County_PCB_Landfill
The use of PCBs in electrical transformers is that they tend not to burn at normal temps when in place. This was a criminal matter and somebody went to jail at least for a while.
The best method of destruction for both of these nasty compounds is through incineration at pretty high temps with fairly long duration times. Too high of temps volatizes any metals though so good controls are a must.
Both dioxins and PCBs can act as endrocrine disrupters, which can be a real problem.
Ray-CA
San Diego CA
I was thinking more about the fire hazard. Dried lumber now add in used motor oil? Yeah, the oil is much harder to get burning then the wood or other petro-chemicals but it is also extremely harder to put out.
Ray
