Used Torque wrench
ChefRex
I bought a a SO inch pound used, had a hard life, gave it to my dealer and came back with a calibration sticker on it, still has scars but if they say it's good I'm good.
BlakeTheCarGuy
Roanoke Virginia
When my Snap-on dealer tested and calibrated my Harbor Freight torque wrench he was surprised to how accurate it was. It was right on point. If you have a dealer see if he will do it. Mine did it free. If you really want another one I’d look for a Snap-on or Precision Instruments one.
Sneezer
DFW, TX
I don't like that style of torque wrench that HF sells at the lower tier. Tekton and others sell the same kind where you loosen the nut at the bottom of the handle. Every time I use those I seem to end up loosening that nut after a couple fasteners.
I have some old Craftsman microtork ones that are still going strong. I test them from time to time, still good. About a year ago I picked up an Icon torque wrench and really like it. The 90 tooth head was super helpful when I had to do some suspension work in my driveway. I did get it at a good discount though, so it wasn't much more than the normal price of a Kobalt/Husky one as I needed it quick mid-project.
corn chip
you might have a look at transcat. they deal in high end torq wrenches and may have some refurbished used ones for sale. ive bought some new ones there and it seemed like a respectable company
Lucid Moments
Gainesville, Ga
I am a big fan of Precision Instruments torque wrenches. I don't know your budget, but these are reasonably priced new and generally well respected.
mercifiknow
Somewhere I should be
I was looking at a used SnapOn on eBay.
mercifiknow
What did cost to calibrate?
FMB4
I check my name brand (no HF) click torque wrenches by using them 'against' name brand beam type units (in my case CF and SK). If the 1/3-1/2-and higher settings ranges are close (i.e. within a few #s then I'm good to go. For 'precision' applications I just grab a beam type (this includes the increasingly common 'torque to yield' applications). Note: I'm retired, so I have no access to the big name tool trucks that always seemed to be pulling up near the service bays. Their 'calibration check/test' prices were pretty cheap IIRC (they used a bench mounted dial type check/test device).
Fly YX
At my work it to$95 to cal. A tw . They have a company come it to do it. We just give them the tools and the company pays for it. It is done once a year. I have hf cdi Precision Tekton Snap on and another two other can’t think of the manufacturer. Have had most of them for 15+ years. Have not had any fail.
Notbn
Ontario
I wish there were more options with higher tooth count heads. I've been trying to find a used snap on 3/8" torque wrench for this reason alone.
mr.lemons
UK
Out of interest, does the calibration company give you a print out of any adjustments they had to make? Wondering how far out of calibration a torque wrench goes in a year, and if different brands go more or less out of calibration.
81turbota
USA
+1 for CDI. They make a lot of Snap Ons torque wrenches, which have a Snap On ratchet head. CDI is part of Snap On industrial, when you order one it’ll be post marked as such. I’m not the biggest fan of CDI’s 3 position ratchet selector but the torque wrench itself is fantastic. It is easy to bump into the wrong position and many at work are taped.
I have an assortment of used SO and new CDI torque wrenches, all tested in a cal lab. Every single one was well within tolerance except a used Proto I replaced with a new CDI.
Fly YX
They do only if it fails calibration. I have never had any of my personal tools fail Cal. I believe the company is Quality Calibration. I know the company owned torque wrenches have failed a few times they are Snap On but it’s mostly due to employee abuse. Using it like a regular ratchet and not putting it back to the lowest setting after they are done using them. If it fails I know they have to investigate and see what aircraft it was used on. I think it’s + or - 4% I will have to ask.
plinker
Northern Wi
CDI & Precision instruments make great torque wrenches. PI's split beams are very nice. Both brands are fairly budget friendly, though they usually have somewhat coarser tooth ratchet heads (which isnt an issue most of the time).
As far as the tool trucks go, if they have a comparator, they can test, not calibrate, to see if the tool is to within spec. Calibration would mean making some adjustment(s) to the mechanism which they would need to send the tool off for that.
This is what the tool trucks (and other places possibly) have to test the tool to see if the tool is actually torquing to 50ft lb when set at that torque.
https://www.protorquetools.com/1-2-...utm_term=4576854590515127&utm_content=Desktop
Basically it tells you within reason that the tool is either good to go or needs to be sent in for repair/adjustment.
TeamTorque is one of a few that does repairs, I had actually bought a used 1/2 drive unit from them when they were selling on ebay in about '09.
http://www.teamtorque.com/
unslow1
Illinois
That's how I check mine also. I've only had one test off and it was visibly damaged.
Ricky Joe
Roanoke, Va.
I bought a Powerbuilt at Pep Boys once when I needed one on a road call. It literally disintegrated on first use. It was a micrometer type. I torque almost everything from head bolts, bearing caps, flywheels, water pumps, intake and exhaust manifolds, valve covers and crank cases; everything. I own about 15 torque wrenches. Brands include 2 Snap-On, 1 Proto, 5 Williams, 1 CDI, 3 Duro, 1 Seekonk, 1 moss berg, probably forgetting a couple. I would never buy a substandard one if I could help it. Some things are worth paying the money for.
jayemm
up high down low
I got an eTORK brand from Amazon. It's the same design as the JS Technologies (and owned by the former owner and designer of JS Technologies) who made them under different labels ( SK, KD, Craftsman, the list goes on) when they were US based. These are made in China now, but the quality is nice, come with a calibration certificate (which is actually believable) and are priced reasonably. For the little use it'll see (1/4" drive, 0-200 in-lb) it should hold up just fine.
mercifiknow
SO is typically +\-2% from what I’ve seen at work. CM and SK are 4%.
Xcursion88
I have the HF torque wrenches. Not pleased with them. I would like to buy a used big name brand as I can’t afford new. My question can I send them off to be calibrated or repaired? What should I look out for? Which would you buy?
Snap-on...
Which? Depends on your usage.
The 1/2" is usually 12.5-250 range
The 3/8" drive is good for 125 ft. Lbs if you find one..(some are only 100)
The 125lb. model will also go down to 5 ft. Lbs or 60 in. Lbs
Ricky Joe
Roanoke, Va.
Snap-on...
Like the previous poster said, it depends on your use. If you can always see what you torque with good access, you can’t beat a beam wrench for reliability and accuracy. A click is good for high repetition. Engines seldom need over 100 pounds, unless you are doing big trucks or heavy equipment. 150 will do just about anything you might need for general work, but inch pounds are great for smaller jobs. What do you need it for?
mercifiknow
Engine and general work on vehicles. Yes I understand the differences. I have smaller stuff that requires in-lbs. My question is about brands and keeping calibration. I will need to decide what ranges to get. Looks CDI might be the way to go.
DeeKay
Colorado
+1 for CDI, that's what we use at work. Zero the scale when not in use and they will last you a long time.
FMB4
There are, of course, several ways to do this. After awhile I started using a 1/4, 3/8, and a 1/2" drive 8 point socket (1/4, 3/8, and 1/2" sizes of course) for this purpose. I just set the clicker T wrench to a particular T setting and then 'connect' it to my beam T wrench followed by working the wrenches against each other with the beam T wrench facing upwards.
plinker
Northern Wi
You can do a lot with three torque wrenches, and would cover most stuff a person would encounter with automotive & such.
For quite a while these were what I had (picked up a couple others since, mostly duplicates and a 3/8 techwrench),
1/2 drive 50-250 ft lb,
3/8 drive 5-75 ft lb
1/4 or 3/8 drive 30-40 to 250 IN LB
mercifiknow
Thanks!
mercifiknow
Engine and drive train work on regular cars/trucks
Lawnmower.
mercifiknow
I’m curious from about CDI’s part number 2502MRMH & 2503MFRMH. The micrometer meaning is that they are only talking about adjusting it in small increments 1# or 5#’s. Correct?
Are these the ones you all are using?
I will check on PI, Norbar, proto
corn chip
i believe some of the norbar might be made in china. thats why i avoided them. pi split beam seems like a solid choice for home use and you wont have to turn the dial back to zero.
