uses for dead space between door track & wall?
EW57
Southeast Iowa
Greetings, in my garage, there is about 12" of clearance between the track & the ceiling & about 18" of clearance between the track and the wall and I'm looking for some ideas on how to use this space effectively as possible.
Initially, my thoughts were a soffit storage cabinet, but there’s hardly enough vertical space to bother, and folding chairs or a ladder might be too bulky /heavy to safely (dis)mount.
Does anyone have any suggestions/pics or tales of woe? Thanks!!
Keep
Oshawa, Ontario
I have a long ladder hung above the door on the front.
On one side I have used screws to hold various yard working tools. The other has just enough space for ladder hanging on the wall and tanks on the bottom.
You can sorta see it behind the drill press:
bad_idea
Pasquotank, NC
Cart is 18" deep x 6' long. I store my sheet goods on it. Being on wheels it will roll away from the wall to easily access the back of the stack. I mounted a couple drawers to the bottom for storage of my scrap metal.
Shelf is made of 2x2"s and a piece of 1/4" plywood. Screwed to the studs and the door track. I use it to store sawhorses on. Only issue is you can't get stuff off the shelf when the door is open.
GarageEnvy
Fresno
Clamp storage, hang your levels, a hose reel, store extra metal or wood, install your speaker there or all of the above like I did. In fairness I had 30".
zjrog
Tooele, Ut
This is what I came up with when I built the shelves.
I need to finish reorganizing this corner now that I bought a HF 13 drawer box, the Craftsman is staying, and the gray box will become a welder cart for my 220 MIG and 110 stick... I have stuff stacked on the upper shelf now. And on the other side of the garage, I just have junk piled in the corner...
Fudge
NorCal
I have a madox handle that hangs right there, just in case someone gets stupid with me. sorry no pics. Theres also a Daisy bb gun there for "warning" the nieghborhood cats.
NUTTSGT
Northern Central Ohio
Off hand this is the first pic that I came to that I have. In the background,you can see my wood rack and a few pieces of blocking stacked up,4x4 & 4x6s.
bad_idea
Pasquotank, NC
What do you use the blocking for NUTTSGT? BTW... I like the pic that just so happens to show off your freshly modified portable weld table. :)
TEX1
Crosby Texas
I built these this past weekend, inspired by this site and this thread. I choose 1x4s and 2x2s, (left overs from another project) for the frame and then I used 1x4s in lue of plywood. I made them 8' long, the 1x4s were 8fts as well so no cutting and no waste. They went up pretty fast too. The chain hanger is just on old 2x4 and some 1x4s screwed to the stud and the door track. I'm hooked on this site.
Charles (in GA)
50 mi south of Atlanta
I have a little more width than you but this is what i did a bracket hung down form the ceiling to hold some long lumber and metal
View media item 9512
uses up the other wise wasted space but leaves the floor clear for other storage
What is that wire rack you used???? I could seriously use something like that for the very same purpose, conduit and Plastic pipe.
Charles
bad_idea
Pasquotank, NC
lol! I swear I didn't steal the cart. I bought it from a guy on CL that got it from an office building that was throwing a couple of them out. Said they were used for moving tables around the building. Either way, I feel good knowing I didn't steal anything.
Steevo
43.49600, -112.04300
Charles
I'm gonna guess it is "cable tray", used in building construction to provide a pathway for laying in low-voltage cabling.
Great idea for using it as storage basket, though!
jayrush13
Lebanon Oregon
That's exactly what it is we got some double shipped to a job and i got about 30 feet of it
ddawg16
S. California
View media item 9511
Charles...that is wire gutter....used typically for wire and Ethernet....the brackets are uni-strut....
jayrush....good use of the wireway.....I'll have to keep my eyes out for some.....
akdiesel
Wasilla, AK
Nice use of space on some of these, but for a "woe", that space is typically used for vehicle door opening clearance.
bad_idea
Pasquotank, NC
I park an 02 z28 in my garage. The door swings open with about 6" of clearance past the plywood. It is very comfortable to get in and out of the car.
