Using coolant pressure tester without making a !@#$ mess!
IsaacJ
Iowa
At work we have a shared coolant pressure tester. It is a cheapo from the auto parts store. It works fine, but..... when I go to release the pressure, I normally get a fountain of coolant from the cap/sealing area. It doesn't do this with pressurized overflow tanks (fords, chevy pickups) just with standard radiators with the pressure cap on the radiator or upper hose.
Is there a trick to these testers? Maybe drain some coolant from the radiator to do the test? Is there a better tool for this? I hate getting a big pile of coolant on the floor when I do a pressure test.
Thanks
malibu101
Walnutport PA
In for the same question.
I have a HF tester. It works fine.
I've gotten to holding a towel around it when pushing the pressure release, that just makes the mess smaller though.
Karl_B
Killeen, TX
I have a Matco tester that I believe is a rebranded Stant. I just release the pressure VERY slowly and only for a second at a time until it is all released. There might be a better way to do it, but it seems to work for me.
I
IsaacJ
Iowa
I'll try some different things, I've released the pressure slowly before, but it just makes a big mess more slowly. Maybe short, slow bursts is the key....
Greg85mcss
Frederick MD
We had a steelman kit at my old shop that was similar to the hf design. Used the pressure release & never had a problem
Jeeper
Round Rock, TX
I think it's impossible to work on a cooling system without spilling at least a half a bucket on the floor.
Just impossible...
redmondjp
Redmond, WA
What is needed is a pressure relief hose that can be directed into a container. That way, the mess is contained. Similar to the cooling system evacuator tools.
rhandwor
Mine has a schrader valve on it like pushing on a valve stem leave out the air pressure.
It doesn't do this with pressurized overflow tanks (fords, chevy pickups) ...
That is not an "overflow tank" it is a remote reservoir. Ford has been using that design on all of their cars and trucks for 15, 20, 25(?) years. Love it !
Chevy-SS
Rhode Island
Yes, me too with this system. I have Stant tester that I have been using for over 30 years, and it still works great!
