Using Impact wrench on fasteners in aluminum threads
R-mm
Impact will be friendly to those threads. And pros doesn't have an apostrophe fyi.
neuralsnafu
Tulsa Ok
On the way out no. On the way in, very light on the trigger, torque to spec by hand..
Sent from my SAMSUNG-SM-G935A using Tapatalk
Danglerb
SoCal
Problem I see is more an issue of rusty bolts that break off and had to drilled out and a timesert put in.
mfewtrail
I've removed thousands of fasteners from aluminum with impact wrenches with no issues at all. You're not going to find many professionals that aren't using air or power tools for removal if they will fit where they're working.
anndel
Hawaii, USA
I used an 3/8 cordless impact to remove bolts but installed them with a socket and ratchet by hand down to mfr's torque specs.
redwrench60
East Tennessee
Loosening? Of course you can. Just don’t be a *******. Look at the work to be done and use good judgment. Tighten critical bolts to spec and use German spec on the rest. I’m not taking this trans apart with hand tools your heads on fire.
