Vacuum on table saw
Chadwilliam1
Cincinnati
I have a 3 hp 220 bolt table saw with a dust collector hooked up to it by remote.
Dust collector is 110 v. My table saw is wired in on a 20 amp double pole circuit.
I bought the over arm dust collector for the saw. I hoped it up as designed where it shares the 4 inch line of a tee. The t really limits the auction but after reading reviews a spray vacuum is desired so I did that and it works excellent using a small ridgid shop vac.
Is there a way I can wire this shop vac to the motor or after the switch of the table saw using one leg. I already have a nutreal in the box where the saw is plugged in I used 12 /3 romex. Now the neutral is capped off in the box.
I was thinking if I switch the plug to a 4 prong plug with the nutreal and inside the switch box after the on switch I could wire in the shop vac using one 1 leg and picking up the nutreal. There so when ever I turn on the saw the second vac turns on.
Thank you.
If it matters it is a 3 hp saw stop.
Sent from my HTC 10
C
Chadwilliam1
Cincinnati
Another reason I want to do it this way is so I will only use one wire because I move it around a lot.
Sent from my HTC 10
CJ7VFR
Central New Jersey
Functionally it will work but the breaker may trip with the saw and vac starting up at the same time.
This was happening to my table saw and vacuum system. I initially had it set up so the saw and vacuum would get powered on at the same time. I had the vacuum plugged in to the saw via the receptacle that was located on the back of the saws power switch.
What I ended up having to do was put the vacuum system on a different switch so that I could turn it on after the saw came up to speed. I don't really mind it set up this way because I can turn on the vacuum system independently if I need to use it for general cleanup near the saw or on the floor.
Jim
matt_i
your other option is a relay tied to a second circuit for the vacuum.
I would recommend this. Wire coil of 240vac-coil relay in parallel with motor windings across both legs of 240vac.
Use normally-open contact of relay to switch 120vac to dust collector on a separate circuit.
mark11
All you really need to do is put a blast gate between your T (a Y is better) and the cabinet and throttle the suction down to the cabinet. My Sawstop is set up the same way and with the blast gate about 2/3 closed I still get good collection through the cabinet and good collection through the blade guard.
dave*99
Coastal NJ
This may work for you. It's a relay that can be triggered by a wide variety of input voltages.
http://www.digital-loggers.com/iot.html
My central dust collector wiring is old school. I have a current sensing switch on the 240V circuit that feeds the table saw, jointer-planer, radial arm saw and thickness planer. The switch senses current on the 240V circuit and closes connection on a separate 120V circuit feeding the dust collector. Google that if you wish. There are plenty of options of that type.
ard
I've got 5 different things piped for dust collection. I had looked at various ways to turn it on but it would also require blast gates that automatically configure based on which tool was being used. I just use a simple remote- and have to open/close blast gates based on which tool is being used
perrysimicart
I would neither pick Snap-on or HF made in China tool. But I would select the tested and approved tool set for outer space with the possibility that I might use it in zero Kelvin temp in outer space. Gold plated is a possibility. Diamond plated is a plus
C
Chadwilliam1
Cincinnati
Thanks for the idea. I ended up going this route because all the complications with the separate shop vac.
Sent from my HTC 10
