Valspar Anti-skid additive
JohnB1953
Ok another new guy question I read somewhere that someone used this in his paint (epoxy I think) and it worked well not a rough as the sand grit. Any one ever used this? I will be useing Epoxy-Coat.
LegacyIndustrial
deerfield, IL
John:
Anti-skid additive added to Epoxy-Coat or similar 100 percent solids epoxy will sink and not be useful. If you need a non-skid, apply a urethane topcoat to the floor within 24 hours of coating the Epoxy-Coat. This will be a thin powerful glaze capable of holding the non-skid media at the surface where it is needed.
Use Soft-Skid or Shark's Grip vs. sand/aluminum oxide. These are products that won't cut your feet and still leave the floor cleanable.
Good luck!
Here is a link to Soft-Skid if you need it: http://legacyindustrial.net/cart/soft-skid-antiskid-additive-p-126.html
jhelrey
MN
I am actually going to do a project with a board that will be exposed to the elements. Won't lie! I am going to use sand on the final coat. The paint is to make it look not so ugly. I could careless about the sand showing through.
