Valve stem core remover
G_P
Central CT
I've got a bunch of the 4 way types. Need to find one thats just a core remover with a screwdriver like handle one of these days.
bubinga
ZRX61,
Its nice to get stuff from the source at times.
Nice! Authentic!
Thanks ZRX61
Yeah, I had one of the 4 way ones, and couldn't find it, so that's why I made this one.
Did youknow....the schraeder valve has not been improved on in 100 years!
wish l had that patent!
Sent from my MotoG3 using Tapatalk
bonneyman
Desert SW
I like homemade tools!
My valve core tools.
First pic shows an old Proto and an S-O core tool, second pic shows the various ones I've found or cobbled together from spare parts. The C&D tool is great - if you have the room to use it. The last one is a nitrogen relief valve for safely letting out the gas in airplane tires (I think).
FlushingDIYer
Queens, NYC
It's starting to heat up around here and figured I should try to get this A/C working on our car. Removed the low pressure cap from my A/C line today only to find it was a little "wet" in there. I'm told that before I try anything else, I should replace the schrader valve and then evacuate the system to see if it holds pressure. And if it does, to just refill it.
Being that this is GJ and we like tools, I was wondering if there were any suggestions for a good all around valve core tool that doesn't look like a basketball inflater pin.
I saw these on Cripe. Are they only for tires? These are called "valve stem torque tools." Is there a big difference here?
http://www.ebay.com/itm/330946701985
http://www.ebay.com/itm/390373810507
mbshop
visalia ca
I have a 4 way and another with removal part and thread chaser on the other end. But my favorite one is a valve cap with the removal part attached. Use it to flatten tires of asshats that block my van.
FlushingDIYer
Queens, NYC
Oh man, I need to try that... :lol:
mbshop, you use something like this?
GETRIDAONE
Auburn, GA
A little off subject but related. I have a Dill tire gauge I took apart to clean up. I was surprised to find a date stamp of March 10 1949 on the inside. I replaced the Schrader valve while I was in there. They still sell the same gauge after almost 70 years. It is nice to see something so simple as a valve that works so well it has never changed !!
johninct
I bought a Snap-on screwdriver one for $5 at a swap meet. Probably paid too much but I have used it many times in the last 10 years.
ritestuff
Little Rhody
Found these old tins the other day. The Schrader tin is minty, and filled with valve cores.
FlushingDIYer
Queens, NYC
Thanks for posting retro, classic Schrader valve paraphernalia. I agree, it's cool to see something so simple last so long. I really hope I run into a S-O valve-core tool one day!
chrisnazzy
Arizona
I carry 2 valve core removers every day at work. A little black hard handle SO valve core remover I've had for years and a new style torquing valve core remover for TPMS stems.
Here are a couple things I have in my collection at home that I think are pretty cool.
1st is a long since discontinued SO TRX400 valve stem tool set that I swapped into a new style tray.
2nd is a Mobilgas dial type tread depth gauge.
rlitman
Long Island
jeeper46
Canton, Mi
I have a number of vintage valve stem caps that have the core removal tool built right into the cap itself.
pepi
Woodstock, GA
Yeah same goes for tolet paper :lol: FFAH
Now you've done it some clown will come out with a new and improved schraeder valve. Using a miro processor and made from plastic, that will not work.
And of course ******** the mechanics gloves, and do a utube demo... lest's not forget that...
Greg
superautobacs
Vancouver, BC
Yup, precisely what I've been using. Way better than anything else commercially available. This combination makes it a one-handed operation, and it's the most fastest way to work schraeder valves on car tires.
Ditch
Paradise Ca.
Yup, precisely what I've been using. Way better than anything else commercially available. This combination makes it a one-handed operation, and it's the most fastest way to work schrader valves on car tires.
Yup, it's all we used in the shop I worked at . There were 4-5 on every tire machine
