VamPliers $20 at Rakuten.com
elronin
Hialeah,Fl
I think you guys are all pretty funny! I've been using old US Petersen Vice Grips to do everything this thing does for about 30 years now! Are you all sure this is so much better? Anyone test all the different options together to remove nails/screws for comparison? - Paul
Yea I think they work just fine, but I would get one for 10 bucks or so.
4xdog
Santa Fe, NM
Paul, you're a pretty funny guy yourself! Vice-Grips have their role -- as clamps. VamPliers are a completely different tool. They have a precision-ground small tip that finds a way to grip things in ways a Vise-Grip would never be able to do. They don't clamp with any sort of locking mechanism -- it's only your grip strength holding on. But that special tip is something else.
I have a dozen or more pairs of Vise Grips, including Petersen stuff from the WW2 era. They have their place in my toolbox, but the VamPliers have their place, too.
Why not get a pair and run the experiment you mention? You'll believe your own results better than anything we tell ya.
pauls_workshop
Indiana, USA - Underappreciated Place to Live!
4x, well, the thing is, I've never had a nail or bolt to pull out that the old vice grips couldn't handle. So my question is are these really worth getting and that much better? What is better if the vice grips have never failed? It does sound like you are giving them a pretty strong endorsement. Perhaps they are worth a try.
But $17 or more for a pliers is not cheap to me or that much of a deal. I'd try them for $8 or so. I like to get most of my tools used and cheap when I find them, generally of excellent old US made quality when I find them too. $2 to $3 each is about what I'd pay for my average hand tool in good shape. If I really needed something, I might buy new for $10 or less, but don't do that very often. It's all about perspective and what is value to you. Tools in general are much more expensive today than 10 or 20 or 30 years back, and I usually like those older ones much better for much less cost used than most newer ones. - Paul
4xdog
Santa Fe, NM
I had to get out toe-nailed tacks in the stained glass window frames I'm restoring. It was a tight fit, and I had to be careful applying force in order not to crack the glass. The combination of gripping relentlessly in a *very* tight spot yet allowing good control of force was a perfect application for the VamPliers. I wouldn't have been able to grab the nailhead with any of the Vise-Grips I have. Heck, I couldn't get a grip with Snap-on needle nose pliers. To have a tool do the job without breaking glass is well worth 17 bucks. It woulda cost a lot more if I started cracking glass.
YMMV, of course, but I'm sold.
Don
pauls_workshop
Don
Hmmm, now you've got even me thinking about this one a bit. I think the above would be a pefect application of where something like this could really help. I do have to admit that the vice grip method can easily mar up the works a bit getting the nail/bolt out. These new pliers have a bit more finesse perhaps. Hmmm. I may file this away in memory for now, but may look into these when they have a *real* sale on them! - Paul
elronin
Hialeah,Fl
No HMMMM Paul just do it, do it....do it..... come on you know you want one. :bounce:
bas157
Near Philly
Does anyone think the slip-joint versions are worth it for a few more dollars? Thinking longer gets you more leverage and a better grip?
Danglerb
SoCal
Clearance in a tight spot vs more leverage, doesn't seem like even the small ones need more leverage, but the obvious GJ answer buy both.
pauls_workshop
Elronin, I am not hasty! (Said very very slowly and in a deep growl, just like Tolkien's Tree Ents in the Lord of the Rings movie.)
I think this concept has some merit however for some applications. One of my old pliers with the jaws worn out may need to experience the DREMEL CUTTING DISK on the end to look like one of these. 3 cuts each way should about do it. I will try it and see if I like it or not as requested but for free! - Paul
elronin
Hialeah,Fl
yea that's not a bad idea, little Dremel or a mini file here and there sounds like it work.
justme-
Boston suburbs
I've been curious about these but figured the steel was soft, much like you are reporting.
I've been using vise grips for years as well with much success. Don't forget there arem, and have been, different kinds of vise grip pliers - needle nose 4 or 6 inch model would have pulled those stained glass tacks no problem.
I find on many screws I need flats cut or ground in them to remove with vise grips, but that's the cost of removal to me. Now having pliers that will do that without needing to cut/grind and will last would be a good investment. How well to these kids of pliers last?
Qualitytools
SOCAL
I Received mine already yesterday in the mail, fast for free shipping and they came with the cover
archirelic
texas
Received my Engineer pliers from the ebay link on Friday. These things are awesome. Kinda sad they didn't come with the cover though like the Vampliers ones...but amazing deal.
Can't wait to put them to use.
