Vapor barrier??
Paul-ish
Lethbridge, Alberta, Canada
I'm just about finished putting in all the insulation in my new 28x30 garage.
It's going to be sheeted with OSB.
Do I need to put vapor barrier on the ceiling before sheeting it?
Any tips for a first timer?
I have the vapor barrier boxes around all me electrical already.
ADCS
Toronto
Depends on the type of insulation you used in the ceiling. Typically it goes sheet rock, vapour barrier, insulation. Same as the walls. Location of the vapour barrier depends if there is living space above the garage (ie before or after the insulation).
dirttracker18
Slate River, ON
Yes, especially in Alberta if you intend on heating your garage at some point.
Run some heat loss calcs with and without VB in the ceiling. You will be vey suprised at the difference it makes.
