Vapor barrier
pameade
Foster,WV
I have a 30x40 metal pole garage, the metal roof has the drip stop on the underside and also have full ridge vent and vented soffits on all sides. Question is do I still need to put vapor barrier up before installing metal ceiling?
Jakemedic
Cornfields of SE Iowa
In my opinion, spend the time and dollars and use a vapor barrier. The tighter you can make your inside structure, the better the heat will retain in the winter. In the summer, it will keep the cool (if you cool it) in. Again, your mileage may vary. But I did that in my shop, although I didn't have drip stop installed. Let us know what you decide.
Firebrick43
West central Indiana
I would to. There is going to be air leakage at the seams, especially at the corners. Put up a vapor barrier and overlap the walls vapor barrier by 6" or so.
P
pameade
Foster,WV
Ok thanks! I will put the vapor barrier up, better to do it now than to wish I had later. Thanks!
LiketoFix
OHIO
Here in Ohio, just North of you we get all kinds of weather including humid summers and rain and snow in winter. My point is we've learned a long time ago that a Vapor Barrier is good in the Right Application. Under a Concrete Slab, (especially), but not below grade on a Block Basement Wall trapping Moisture and causing Mold and Rot, Musty Odors, etc..........Hence A Vapor Barrier is Good in this Application like Your Roof, But a BREATHABLE Vapor Barrier is what I'd be Looking at verses Plastic or Visqueen. Tyvek Paper is a good Product for Walls above Grade on wall board Sheeting as it resists water and moisture with it's wax coating on it. Yes Plastic is a Vapor Barrier but it can also trap moisture which causes Mold, Odor, etc.............
It's good to keep Moisture out but be careful not to trap it in! Without going into several stories I know for a fact that you have to be carefull with not trapping moisture in! IMHO!
LtF
Firebrick43
LtF
Its a ceiling against a traditional attic with proper ventilation. Its not going to trap moisture as both sides have ventilation. Mind boggling that you would recommend tyvek in this application. It belongs on the outside of walls.
LiketoFix
OHIO
I probably didn't explain myself properly as I didn't suggest Tyvek in this application, I only referenced it on exterior walls above grade.
My Bad !
LtF
P
pameade
Foster,WV
I just don’t want the metal on ceiling to sweat and drip
LiketoFix
OHIO
It never hurts to keep fans moving air to eliminate condensation weather it's ceiling fans or others. Air movement is important!
LTF
rebelranger
After much consideration I skipped vapor barrier above the metal ceiling. I did blow cellulose on top of the liner panel ceiling though. Thus far 0 condensation during -5 or 95 degree midwest weather [we get literally everyweather condition possible] . The walls are 1.5 closed cell then r11 fiberglass, there is r7.5 rigid foam under concrete, and estimated r19 cellulose in ceiling [ I plan to put additional r19 in jan] I wanted any settling to occur before in added the last r19.
