VCT: How to handle raised area?
threadhead
Valley of the Sunstroke
I've been contemplating VCT for a while, but the one issue that keeps me from pulling the trigger is that I have a raised area, about a 4" step, that runs the length of the garage.
The face of the step is fairly smooth, but not perfectly perpendicular the the plane of the floor.
How would I tile this area?
How would I protect the edge?
sharpshooter
West TN
Can you post any pics of the areas. I saw a few pics on here somewhere, where a guy used the vct to go up the base of the wall a little but, not sure if it was a ledge or not though... you might could use some type of rubber stair molding for the edge of it... need pics for better idea of what you got goin on.
Fudge
NorCal
I think I would shim and sheet, in some sort of plywood. You should be able to square it up then. Make sure to put a bull nose on the ledge or they will break.
boiler7904
NW IN
If the step is 4" or less, you can use a rubber or vinyl toe-type base like you see in commercial buildings for the vertical face or cut VCT to fit. I would use a rubber nosing to protect the exposed upper edge. Mannington is one manufacturer.
Mannington Rubber Nosings
