A&P mechanic
Hey Guys,
I am looking for a very small snap ring plier to remove the snap ring in the picture. I have a full set of standard sized snap ring pliers by SK but I have never actually seen any snap rings this small before. I contacted the ratchet manufacturer about getting a replacement snap ring but would like to get the correct size snap ring pliers because I may need to do this again in the future.
The snap ring is on the back of the roller ratchet head. The ratchets are for installing/removing hi lok fasteners.
This is the set of snap ring pliers I have but even the smallest SK plier is to big. SK Snap Ring Plier Set 7780 “18-degree cam-lock retaining ring pliers in the following sizes: .038-inch, .047-inch, and .070-inch; 90-degree cam-lock retaining ring pliers in the following sizes: .038-inch, .047-inch, and .070-inch; blow-molded plastic case.”
Thank You!
Thank You!
