VFD for a Bridgeport Mill
WhoWhatNow
Collegeville, PA
I need a VFD for my new Bridgeport mill. The mill is a 1hp 220V 3ph motor and I only have 1ph at home. Many people on Practical Machinist recommend the Teco FM50 for this application. I found a second TECO drive for not much more money and was wondering if anyone can tell me if there are any advantages over the FM50. As near as I can tell the difference seems to be a dial vs. buttons for frequency control.
This is the FM50:
http://dealerselectric.com/item.asp?PID=4542
http://www.tecowestinghouse.com/PDF/FM50(08.04).pdf
This is the EV:
http://dealerselectric.com/item.asp?PID=4708
http://www.tecowestinghouse.com/PDF/EV_Micro_Drive.pdf
rsanter
visalia ca
Have you though about calling TECO and asking them?
TECO is a good drive. The one with the dial would be a little better for mounting up at the head. If you are going to mount in an enclosure and run a remote then the push button model would be better
Bob
Cryptic1911
Willimantic, CT
I'd probably get the one with the dial. I bought one of the huanyang chicom specials, and it works fine, but it's got the push buttons on it. I can hook up an remote potentiometer, but it would have been nice to have it right on the vfd itself
pete379
Teco are good drives. I've got 3 (mill,lathe,drill press) they have built in potentiometers, but on the mill I use a remote pot. Mine are FM-100
pete
