Looking for some advice on how to dial in this setup:
SEE UPDATE on post #5
Machine- Grizzly G0614 1.5hp swivel head metal band saw
VFD- Mysweety 2.2KWH unit 2.2KW 220V VFD: Input voltage: 220V(+/-15%); Output voltage: 220VAC; Input frequency: 50/60 Hz; Output frequency: 0-600 Hz; Input phase: 1 phase; Output phase: 3 phase
Good news I have it running and all seems fine? This is my first attempt at setting up a VFD and would like to confirm I have this running at optimal conditions.
The only parameters I have tweaked is the power input dial. I calculated Feet per Min to Blade rotations and have the blade spinning at roughly 170 FPM / 341 FPM w the power input at ~83%
Questions:
Q- Is the power input dial the ideal way to adjust the power going to the machine and setting the blade speed? If not, what is?
Q- Are there other parameters I need to be concerned about that would negatively effect the motor/electronics? The instructions are bit vague on checking things like frequency etc...
Thanks in advance ( I may post this separately if this thread doesnt get much traction)
Questions:
