Vintage Drill Press Slow-Speed Pulleys
JZiggy
Atlanta
GA
Price
200
Price shipped USPS: $200 via PayPal
1/6/26 -- Almost 5 years supplying the upgraded kits with consistent positive feedback from customers. Slight price adjustment reflecting increased cost of materials.
10/9/21 -- I am kicking off my new and upgraded design! There are a couple ready to go and I'm making more presently.
Here's my own Craftsman drill press thread complete with the original design and ideation of my aftermarket slow speed pulleys. The design has been updated from what is shown in this thread.
I have been offering these pulleys for sale since 2015 and have had great reviews. It's been great fun to work with so many GJ'ers to adapt and customize these pulleys to fit their vintage drill presses. Awesome to get ya'll drilling sloooowww!!
Disclaimer: I'm not a machinist, and I'm not doing this for money. I enjoy putting quality, vintage tools to work and helping others do so. I like coming up with creative mechanical solutions. These pulleys are made with a Craftsman 100 drill press, a Craftsman belt sander, a vise, and hand tools. No mill, no lathe.
What your $$ will get you... One slow speed pulley and an adapter shim (if needed): Pic 1 in attachments
The pulley allows up to a 3:1 reduction or increase. So for a standard Craftsman drill press with a 4-step pulley system having a 700 rpm minimum speed, this would allow a slow speed of about 200 rpm. I measured 188 rpm with a tach on my own machine. You can also flip the belt and increase the maximum speed but I don't recommend it since the spindles aren't designed to go much about 5000 rpm.
These pulleys fit many Craftsman and Delta drill presses with round columns having machined IDs between 2.375-2.500". I will supply an adapter sleeve to fit ID's over 2.375". I can customize these to other ID's from 1.5"-3" and possibly more. The pulley position can also be raised to adapt to older style presses with "swoopy" head designs. So if you're not sure please just ask -- I have made pulleys for lots of different drill presses!
The concept is the same as the factory multi-speed pulley. The assembly drops into the top of the column, tightens against the spindle belt, and is locked into the column with an angled set screw.
Pic 2 -- Column shown with adapter in place (adapter only needed for 2.450-2.500" columns)
Pic 3 -- Slow speed device installed, pulley removed showing only the base so you can see how it fits into the column.
Pic 4 & 5 -- Here is the slow speed pulley installed. The front belt is tensioned by putting a 7/16" wrench on the flats of the shaft and rotating it. Once you get the correct tension a 5/32" allen wrench locks the set screw against the ID of the column (wrenches not included)
Pic 6 -- The motor belt is then tensioned in the usual way (however your drill press was originally designed to tension it) and you're ready to drill!
The pulley kit is made with four sets of needle roller bearings to make sure it moves smoothly in rotation and if there is up/down thrust from belt misalignment. The bearings are easily regreasable if needed in the future.
I also encourage you to refer to GJ member 11b30b4's very nice writeup of my pulley install (older design shown)!
What other parts do you need?
1) A pair of v-belts. Usually a 29" and 27" are what you need for a Craftsman drill press. These standard part numbers are 4L290 and 4L270. I ask users to source belts on their own in case a different size is needed for the application. If you want me to get belts for you I'm happy to help.
2) A 7/16" or 11mm or smallish adjustable wrench
3) A 5/32" allen wrench (does not have to be tee-handled)
Feel free to PM me if you need more information.
note: thread edited and revised 1/6/26. Prices updated to reflect increasing cost of materials.
J
JZiggy
Atlanta
Here's a batch of pulleys ready to go!
J
JZiggy
Atlanta
With the help and collaboration of another GJ member I came up with a solution for the older-style drill presses which use a center slow-speed pulley that is mounted a couple of inches higher. These are common on the pre-1950's presses including some Atlas and Delta one. They use a pulley like this (pic 1)
Using a longer shaft and a spacer, we have a perfect solution! (pic 2)
Here's another example of a GJ'er's Delta press fitted with a customized pulley (pic 3)
I can offer these pulleys as a special order. If you need one, let me know.
J
JZiggy
Atlanta
Another picture of a batch without pulleys installed. These sure are fun to make.
J
JZiggy
Atlanta
Still time to get some pulleys for stocking stuffers. I have 3 left ready to ship.
J
JZiggy
Atlanta
Thanks for the orders, guys. I did the smart thing this time and made an extra big batch of pulleys. There are still plenty available.
I had another custom order wherein we raised the pulley position about 3" to help it fit one of those late 1960's Craftsmans with the 6" quill travel. It's always cool to find new applications for these.
J
JZiggy
Atlanta
Thanks for those who participated in the 2019 moving sale! I'm settled into my new place and, more importantly, the new shop. Pulleys are available!
J
JZiggy
Atlanta
One of my customers was kind enough to snap a picture of their JZiggy slow speed pulley installed on their 13" Craftsman 80 with 2" ID column. I can adapt these designs and have made them successfully between 1.5" to 3" bore sizes.
J
JZiggy
Atlanta
It's been cool to see folks utilize these pulleys on more than the Craftsman 100 and 150 models. Folks have fitted them successfully to various Deltas, Homecrafts, and others. Whatever model you have it can benefit from the lower speed and increased torque from gearing down.
Happy drilling!
J
JZiggy
Atlanta
If you're working from home (or not, or whatever) and feel like finally gearing down your drill press hit me up!
J
JZiggy
Atlanta
Got another batch of these in the works. All metal, four sets of bearings per pulley, built to last a long time and provide serviceability.
J
JZiggy
Atlanta
The slow speed drill press factory as it currently sits. It's a lean, mean, (slow) drilling machine!
J
JZiggy
Atlanta
I made my first 3" base pulley this week. This will go on a 20" Walker Turner which is the biggest press I have ever made a pulley for!
Edit -- turns out we needed up upgrade this puppy to a special 5 step pulley to get it to work right with this machine. Turned out great!
J
JZiggy
Atlanta
Got some great pictures from a GJ'er who installed his pulley on his super nice Craftsman 150.
J
JZiggy
Atlanta
A GJ'er recent installed my pulley kit on his immaculately restored 150 and was kind enough to share some pictures and give me permission to put them in my FS ad. I love the fact that he took the time to polish the pulley on his lathe -- really puts it over the top!
J
JZiggy
Atlanta
These pulleys are still available. I will likely sell this last batch of 6 and be done for a while so let me know if you're interested.
J
JZiggy
Atlanta
Fellas, I wanted everyone to be aware that I am currently working a design update to these pullies. Component supply and pricing has forced me to do something different but I think I may be able to come up with a solution that is even better than before. Be patient with me as I sort this out and do let me know if you're interested.
My goal is to keep on making these reducers for folks that want to gear down their older drill presses!
J
JZiggy
Atlanta
New design is coming along well! I have a prototype running on my own drill press right now (y)
J
JZiggy
Atlanta
Here's a look at the newly designed pulley setup as of 10/2021. The wider pulley diameter means that this pulley provides a higher gear ratio -- more than a 3:1 reduction! I measured below 200 rpm on my own Craftsman 100 with factory motor and spindle pulleys! The sheaves are also spaced closer so it is easier to change speeds.
J
JZiggy
Atlanta
Got a couple of these in stock and just ordered supplies to make another large batch. Contact me if you're interested in a slow-speed pulley.
I recently made one for a 13-1/2" Craftsman that utilized a smaller custom base and riser. Turned out great.
J
JZiggy
Atlanta
Bump! I am about to start a jumbo batch of these pulleys. In the meantime I do have one for sale at a $25 discount because it has a extra unused hole in the base. Once installed it's not noticeable and doesn't affect the operation in any way. LMK if interested!
J
JZiggy
Atlanta
I recently had the opportunity to make two custom slow speed pulleys for GJ members with smaller Craftsman 100's or 80's. These have the 2" ID columns rather than the standard 2.375" or 2.475" seen on full size presses. The members were kind enough to share install pictures and provide some feedback (sharing with permission):
"Dude. Works amazing. Drilled a 1/8 hole through 1/2” square in a fraction of the time I could do it by hand in something thinner than 1/4.
I can’t reply to your sales thread I guess. I was going to leave you a glowing review and hearty thanks for the help and service. FYI I used a 25” belt on the motor side and a 27” on the head side. Works swimmingly. I also used the recommended Continental belts.
Thanks again man. This mod is really improving my life. Stay cool and keep making stuff!"
This is why making these pulleys continues to be fun even after 5 years! :cool:
J
JZiggy
Atlanta
Happy New Year, folks! I've got a couple pulleys ready to go and other big batch in process. Feel free to contact me if you're interested or have questions about a custom one for your drill press.
J
JZiggy
Atlanta
I recently made a custom 5-step pulley for someone on the board. That's the great thing about this design is that it is straightforward to adapt to different styles of drill presses.
J
JZiggy
Atlanta
Bump! I've got a batch of these ready to go out the door. Just PM me if you'd like to know more.
J
JZiggy
Atlanta
The weather's getting nicer and drill press restorations are on the rise! Let's get a slow speed pulley for your new build to get you drilling some metal :cool:
J
JZiggy
Atlanta
A GJ'er installed my kit on his Delta DP220 benchtop model. He utilized a small spacer to avoid dropping the head casting down. He reported getting measured rpms below 150 (!!!) and and sheave spacing lined up just right. Here are a couple of pictures he graciously offered.
Side note, I am getting near the end of this batch soon. I may have to reevaluate pricing when I do my next one since the prices of the raw materials I use keep increasing.
J
JZiggy
Atlanta
A GJ member asked me to make a custom pulley for his early benchtop Craftsman (later Dunlap) 12-1/4" press with the little 2" OD column. I used a 1.5" base and it turned out nice! I think this is about as small as I can go with this design.
A big thank you to all you great folks that let me keep this hobby going. It's fun to engage with members about their drill presses and I get a chance to see how these center pulleys get used on a variety of different designs -- always a fun learning experience for me. I only advertise on this board and it's neat to see how many people contact me that create GJ profiles just to send me a PM. Hopefully they take the opportunity to plug into this community and make the most of their vintage tool interests along with us.
J
JZiggy
Atlanta
Hi folks,
Recently I've had a few people create accounts in order to PM me and there has been some confusion as to how to do that. I wanted to offer an alternative: you can email me directly at jziggyt4r (at) gmail (dot) com
Mods, if listing this contact is not allowed please inform me and I'll remove it.
Also, since this is a For Sale thread users can't respond to it. So if you try and it doesn't work that is the reason.
Thanks!
J
JZiggy
Atlanta
Hard to believe that 2024 will be my 8th year of supplying aftermarket drill press pulleys to the vintage drill press contingent of GJ!
If you're interested in snagging one I encourage you to do so soon. Next year I will need to bump up my price again due to the rising cost of parts (though fortunately the aluminum I make my bases out of has actually gone down a buck or two!)
Thanks for everything!
J
JZiggy
Atlanta
Turns out I am able to keep my price the same for now, yay! $175 shipped
Got a batch handy, let me know if you're interested.
J
JZiggy
Atlanta
Bumpalump! Got about a half dozen of these ready to go. Have had a handful of folks fitting these to various vintage Deltas recently.
J
JZiggy
Atlanta
A GJ member was kind enough to share a picture of their Craftsman 150 equipped with the JZiggy slow-speed pulley kit and a pair of cogged belts. He reported getting under 200rpm on the lowest setting, giving great results in metal.Pulley 5-2024.jpeg
