Vintage Gedore Dremometer Restoration (PICS!!!)
crazymonkey2465
San Antonio, Texas
So I picked up this Gedore Dremometer torque wrench not too long ago, and decided to go though the insides and make sure everything was working good and not rusted or anything. Here is some pictures of my progress so far.
Here is the wrench, I believe it is from the 80s, but there is no date stamp anywhere.
Close up of the top plate. 15-90 lb-ft range.
Close up of scale.
To take it apart is pretty simple. First I tapped out the four roll pins holding on the top plate. Just hit both sets out with a long punch from one side. Then tap the square drive with a hammer to raise the plate a little, and persuade the plate off from there. The fit is pretty tight actually, I assume to help keep water and moisture out of the lever chain mechanism.
Now the square drive and intermediate lever slid up and out along with a spring and a dowl pin. Next the preload on the main spring needed to be reduced, so I set the torque value to zero. Now the second dowl pin came out, along with the last lever chain piece and two washers.
Now I turned my attention to the bottom. There is a snap ring that needs removed.
I punched out the two roll pins from the bottom as well.
Now the whole lower assembly slid out.
To properly clean all the parts, I also removed the adjustment knob from the assembly. If I recall correctly they are reverse threads.
That's as far as I have gotten for now. I am debating how I should clean up the body of the wrench. I want it to look good, but also have a durable finish so that it looks good after years of use. Any suggestions?
C
crazymonkey2465
San Antonio, Texas
So my current options are...
* Spray Paint
* Polish the Aluminum
* Powder coat
* Anodize
* Hard Anodize
Those are the options I can think of for now, and I think I'm leaning towards hard anodizing. Anyone have experience with hard anodizing? Or have any other suggestions?
LXCam
This will be a pretty cool thread if you can get a handle on sizing the pictures. As for finish, I'd re-machine the gouges out if you have enough meat and just polish it.
C
crazymonkey2465
San Antonio, Texas
Are they pictures too big? They look good to me on Tapatalk. I just uploaded them from my phone using the app. What's the best way to upload pictures on here?
And there aren't many gouges on the body, just mainly scratches and oxidation. I would like to have a coating or something to protect against the oxidation in the future.
C
crazymonkey2465
San Antonio, Texas
Here is a slow motion video I took of the lever chain mechanism for those of you that are curious on how it works.
I also resized the pictures today, sorry guys!!
C
crazymonkey2465
San Antonio, Texas
Cleaned up all the small parts today, brake clean and simple green worked out nicely.
I also got a quote from a local anodizer today about doing a black hard anodize (Type III) on the body of the wrench. I think the quality and durability of the coating will be worth the extra cost when all finished. I will probably drop it off tommorow or Friday some time.
C
crazymonkey2465
San Antonio, Texas
Picked up the wrench from the anodized today, looks pretty good in my opinion. I'll probably put it all back together tomorrow if I get a chance.
C
crazymonkey2465
San Antonio, Texas
Got it all together today
Here are some before/afters
