![IMG_0479[1].JPG IMG_0479[1].JPG](https://www.garagejournal.com/forum/data/attachments/1529/1529493-f7059ec1bb7e6296a2db393b654afbb6.jpg)
![IMG_0502[1].JPG IMG_0502[1].JPG](https://www.garagejournal.com/forum/data/attachments/1529/1529499-69326cf40674604897c41124f382eb02.jpg)
![IMG_0487[1].JPG IMG_0487[1].JPG](https://www.garagejournal.com/forum/data/attachments/1529/1529501-95e2f3f6b05657cfed430f12fb509fdc.jpg)
I'd really like the main motor label and on/off switch label re-done in aluminum. I did manage to save them in the resto but they detract. Also, the top safety sticker would be a bonus or really any age appropriate "PUT ON YOUR GLASSES" style label would be great...I need the reminder
Additionally, I had some Baldor vertical vinyl stickers made for my sander. The creator was kind enough to send me some additional color options so, I can pass these along if anyone can use! White or some shades of blue....
Here they are in brass. The dimensions are 4-3/4” x 1-1/4” which is slightly different from what you measured but this was the size needed to match the proportions of the supplied photos.Any chance I could commission you to make a couple badges for a Radial Arm Saw I'm restoring out of Brass? If brass is not an option, aluminum works too!
My badges are 1.125"X4.75" - the file attached might be slightly different ratio. I would not need holes for the rivets as my saw doesn't have drilled holes (existing badges were glued on). Let me know if you're interested and the cost - thanks!
I recently restored my Baldor M109/385 grinder. It looks really nice now. The data tag and Shield decals were reasonable shape and I kept them as is. However the Baldor label on the pedestal was attached crooked and was in pitiful shape. I scraped it off with a razor blade before sanding the pedestal clean. I see you have made one for your pedestal. I would very much like to replace mine as well. Could you please contact me with details if you could make one for me? TIAA beat up old sticker on a newly restored grinder makes it look bad. Many restorations require that the label be removed (and destroyed in the process) to repaint. When I restore a grinder I go all out - sandblast, paint, new bearings, replace cord, replace rubber feet, etc. I want my old grinders to have no problem lasting another 20 (or 40) years of heavy use before they look worn out.
Besides the old label my restorations look new.
Sometimes I need to remove the old label to sand and paint and sometimes the old label is damaged and needs to be replaced.
Here is a recent Baldor 3/4 HP from 1978 that I picked up for $200 a few months ago and is undergoing a restoration.
Solid grinder but it was heavily used and ready for a full restoration. This requires that I remove all the old stickers and sand blast it.
Here it is partially restored. Only new parts are the bolts to attach to the stand, the bolts to attach the polycarbonate sheets and the new labels. I still need to attach nameplate and switch cover which I ordered new from Baldor.
Baldor also sells the adhesive labels but they are overpriced in my opinion so I made them myself. And besides, Baldor won't sell the UL label.
These labels were drawn on the computer using the old label as a template. I scanned the old label in on the office copy machine then used vector based drawing tools to make a perfect replica. These labels are within 0.01" of original.
I print them on silver or white high performance adhesive vinyl using solvent inks then machine cut them to size (the cutter automatically rounds the corners). The hard part is creating the electronic version of the label. It can take an hour or two for complex ones. The printing and cutting take just a few minutes.
It's actually no more effort to print out 8 then I have a few extras in case I mess up.
These are unlaminated so they are damaged with alcohol based solvents but are water and light resistant. For more durable labels I add a high performance clear laminate prior to machine cutting. That does complicate the cutting process as the machine needs to re-orient the print origin but then the labels are impervious to chemicals.
Here's one I did for a craftsman grinder last year (this is the spare one that didn't end up getting used). This one took about 90 mins to draw.
And some for another machine I'm restoring
I use professional sign making software to do the layout (FlexiSIGN) which allows for fast and accurate drawing in vector format and can import and export EPS and PDF files.
All these labels (except the yellow/black ones) are extras that I don't need anymore. If you can use a any let me know and PM me your address and I'll send them.
I may regret saying this but I will also make any adhesive label for a grinder for free (at least until I get overwhelmed). If you need one post up a photo and I'll let you know of that is one I can make.
PM sentI recently restored my Baldor M109/385 grinder. It looks really nice now. The data tag and Shield decals were reasonable shape and I kept them as is. However the Baldor label on the pedestal was attached crooked and was in pitiful shape. I scraped it off with a razor blade before sanding the pedestal clean. I see you have made one for your pedestal. I would very much like to replace mine as well. Could you please contact me with details if you could make one for me? TIA
I can make this. Any chance you can get a flatbed scan of it that I can use as a template for size and position?This is my first post on here, it was suggested to me and linked from the HAMB. Could you reproduce this one? It’s adhesive backed foil similar to the Craftsman grinder tag in post 494. I don’t need the stamped numbers, just the blank sticker. Thanks.
Here you go!Hi Matt, I am hoping you can help me out. I am in the process of restoring my old grinder. In looking for decals I ran across this forum. Is this something you could make for me? If so just let me know the cost. Thank you.
Here is the completed label. Post a photo of it installed when you have a chance.Is this image clear enough to create a duplicate? A single voltage 3 phase 200V grinder is not as common as the 230/460V 3 phase, or 115/230V single phase models . For those who don't know, 200V is for use on a 208V system.
When I bought my grinder the tag was missing, it came from a school in Truckee, CA.
Never done this one before, but happy to do so.Matt I'm amazed at the work you are doing here and I'm ready to give you some more work if you're down for it. I'm not sure if you've done this one before but if not let me know what you need to make one of these. Thanks
