Vintage S-K Tools
wonder what would be a good way to keep an old catalog (I might be getting something soon (Not the 1940s SK catalog I posted above, but it will be an interesting one)
I have a 1935 ish catalog from a localhardware distributor that has fabric covered ¿Masonite? Covers, held closed by binder posts. There are various pages with different dates, indicating they too were updated. You could make a snazzy cover of your choosing, and use binder posts (Chicago bolts, *** screws depending on where in the country you live.
Shelbylex
Thank you, Outlawmws. That's a lot of catalogs! I almost wonder if I should start digging another rabbithole and periodically look for old catalogs (I love reading and there were several books which were hard to find Sci Fi books which took me some years to locate and purchase. The longest search for a book I had was more than a decade (to be fair, I just remembered names of 1-2 characters and not much more (the magazine which published the book disappeared and I had neither the author nor the name. Than one day I discovered google books advanced search looking for a book of Dietz which I could not locate in my small library))
It could be an expensive addition, but may be I can find some on yard sales?
RTM, appreciate it as well. If you have a chance, could you make a picture?
I’m gradually making progress on the 4809 set in progress as the sockets come in. Here it is with the sockets I had on hand. IMG_7545.jpeg
After the 15/16” socket arrived and was cleaned up. IMG_7724.jpegIMG_7728.jpeg
The 1-1/8” socket arrived today and I added it as well. I had repainted the bottom of the box since so much of the paint was missing.
IMG_7775.jpegIMG_7782.jpegI wanted to see what it would look like complete so I borrowed a 3/4” and 11/16” socket from a complete smaller later set. IMG_7784.jpeg
The larger set should be completed in a few days, if the USPS cooperates. 😳
With the arrival of the 3/4” socket, I’m on the home stretch. The 11/16“ is supposed to arrive on Monday. IMG_7795.jpegIMG_7796.jpegIMG_7797.jpegIMG_7795.jpeg
The 11/16” socket arrived today to complete the set. I sanded and painted the bottom of the box which was pretty rusted. IMG_7939.jpegIMG_7940.jpegIMG_7941.jpegIMG_7942.jpeg
Now that the set was completed, I moved it into the S-K area of the basement display. IMG_7951.jpeg
Thanks to bmwrd0 for the box which allowed me to put together a set that I didn’t previously have. It’s been a fun project.
Due to the catalog images in early S-K catalog images being notoriously inaccurate, I can only say that they started using that riveted on tag in 1946. The diamond shaped embossing around the drawer pulls leads me to believe that your box is quite early. It is shown in the 1953 catalog as well as the artwork in the 1949 catalog.IMG_8945.jpeg
That’s a very nice example. I would be happy to find one of those at a sale.
Provincial
Near Salem, OR
I was at the nearby Restore today.
I wandered around and discovered that they had expanded the inventory space to a covered outside area. There I found a large Kennedy "hip roof" toolbox in pretty good shape.
Missing the tray.
Oops! It wasn't a Kennedy!
Another item I picked up there was a Chrome Alloy 31/32 socket.
Shelbylex
I have a lead on this tool box. It appears to be 119C box from what I see, similar to this one https://www.worthpoint.com/worthopedia/sk-tools-sherman-klove-co-metal-tool-box-old except for the size (119-C is longer (19 x 6 x 6.5 box))
I think I saw a couple of them on the board, but I do not remember when...
Is it possible to get the key for this type of box (the owned told me that there is no number on the lock on the outside). I think this is an Excelsilor lock. Is there a code somewhere on the box?
I am not sure what I will use it for, but thinking. If you have one - please post the picture and what you use it for (it almost looks like tackle box with the drawer going up when you open the top)
Thank you
P.S. how old it is? 40s-50s?... Probably later - the handle appears to be plastic. Earlier ones had leather, I think
Shelbylex
Thank you, Don. Will try to get more pictures from the seller.
It's interesting that the moving tray has 4 cylindrical shape spaces (they could have used vertical dividers instead). I wonder if it's for storing small parts/bolts/what not there and making it easier to take those things out.
JonahBrown
This S-K Chrome drag link bit arrived in the mail today. The copper plating is all that shows. I wonder it it missed the nickel and chrome plating steps. It doesn’t look like they are missing from wear. IMG_7201.jpegIMG_7202.jpeg
If someone cleaned it using electrolysis, they could have removed those layers of plating. Just a thought.
Mintgrun
Kingston, Wa.
The polarity is the same as plating, so how could it remove plating?
The polarity with electrolysis is the opposite of plating. The tool is the cathode (-) and the 'sacrificial' conductor is positive (anode).
That said, I've never had it remove sound plating. I assume loose stuff sluffs off and contaminates the solution. I figure it'll mostly settle to the bottom, but generally consider used solution to be somewhat toxic, even though it starts off as a simple mix of water and baking soda, or washing soda. I keep a bucket setup on wheels that let me roll it under the bench when not in use. I am a fan of that process. : )
Beerhippie
Far NE Oregon
Nope. They should both be the same polarity: Negative to the work, positive to the sacrificial anode.
I just double-checked my pictures of both.
Mintgrun
Kingston, Wa.
Okay, sorry. It's been over thirty years since I've done any plating (copper) and I was just a user of the system, not the maintainer.
The way I remember polarity for electrolysis is "the negative material is moving toward de-positive side."
I assumed the plating was being deposited. The bath solutions are very different... sorry for floating off topic and adding confusion.
Thank you
Here is my smaller version. My best guess is 1945. IMG_8005.jpegIMG_8007.jpeg
IMG_0308.jpeg-Don
Shelbylex
Thank you, Don. If everything goes well, I will have the box relatively soon (trying to figure out when we can meet, agreed on the price)
Got another picture. The owner told me that ithe box is straight (looks a little bent). Interesting how the drawer is reversed compared to yours.
Shelbylex
I got myself newer SK ratchet, extension and some sockets The owned thinks that the box is also SK, but I am not sure - the divider is slightly above the level of the bottom (not sure if the picture will show it well) and there are side holes which hold it.
I suspect it might be not SK. Does anybody know?
The sockets are SAE. I noted couple of sockets with square marks on them in several locations. Does anybody know what they are from? (interestingly, I saw similar marks in the same pattern before, but only on SK sockets. Assumed that somebody used pliers or something similar to on the socket the first time, but they look very similar on this new set
... I will probably make a user set out of this one. May be try to spray some green paint (?Rastoleum Hammer Green) in the summer and cover the bottom with some thin mat
SKbox_1.JPGSKbox_2.JPGSKbox_3.JPGSKbox_4.JPGSKbox_6.JPGSKbox_7.JPG)
Mintgrun
Kingston, Wa.
I have been looking at this FB MP ad for "Vintage Craftsmen Rollaway Toolbox" and wondering who made the roller under the heritage box. Now I know! It's an S-K Red Tool Wagon. Although, it isn't red on the outside anymore and it is missing the two tote tool trays. ($300 for the pair in Tacoma, Wa. listed a week ago)
Shelbylex
Me too.
Don, out of all of us you are probably the one who already has all the pieces to complete the set and restore this box! We already have 39,41,43 catalogs and know what should go in there...
Do you really want to avoid this headache???
I texted the person to get the story behind the box and to see if I can somehow magically get in touch with the previous owner to see if there is a tiny chance that the tool totes are still sitting somewhere with tools in them (even if I can not buy them, I would like to know if the paint was wrinkled and how the dividers looked). So on no reply : (
Shelbylex
I am glad I am on the other side of Portland, as that would be coming home with me otherwise.
Wife would kill me, but what is new.
I collect all those rusty tools and boxes only having my wives health in mind. I want her to live long and am afraid that if I do not bring them all home, she will die of happiness!
Shelbylex
I need more tool boxes like another hole in my head.
You are located in the same town!!! You do not feel the subconscious magnetic sensation of needing the box in your garage???
Agree though, it is a project with the big dent...
Upon further consideration, I would find some way to make space for a nice Plomb Toolmobile. 🤑
