Vise Info Thread
maico
England
Thanks Maico, sure have given me a bunch of work to do. I still have not added your other European vises to the sheet yet. Do you know if the older ones are the same as these newer Bison Vises?
The Leinen style rear jaw type appear to have been made by Bison for many years judging by all the old ones that turn up on Polish ebay.
Here's a miniature one that surprised me....of continental appearance but made in England
https://www.ebay.co.uk/itm/Vintage-...e=STRK:MEBIDX:IT&_trksid=p2060353.m1438.l2649
maico
England
KMScott
American Scale #50. 5" Jaws that opens to 5" and weights 40lbs.
KMScott
Athol 23-1/2. 3-1/2" Jaws opens to 3-3/4 and weights 19lbs.
E-bay seller mentions.
"It's worth noting that this vise has the ''lift pin'' type of swivel base.The pin lifts up and slips into one of several holes allowing to rotate the vise on it's base and be locked into several different positions."
KMScott
Reed #23. 3" Jaws that open 4" and weights???
KMScott
Columbian Hdwe Co. Cat. No. 144M. 4" jaws that open to over 6" and weights 23lbs
KMScott
Dunlap 5236. 3-1/2" Jaws that opens to 4=1/2" and weights 21lbs.
maico
England
Superb Japanese O-Gon vise clearly made to high tolerances. 'patento' is Japanese for patent.
Photos from interweb trawl
KMScott
Prentiss #212. 3" Jaws that opens to 4-3/4 and weights 17lbs
KMScott
Rock Island 505A. Maybe 5" Jaws. Need more info.
KMScott
Rock Island # 91. 3" jaws that opens up to 4" and weights 22lbs
KMScott
Craftsman 5181. 4 inch jaws that opens to 6 inches and weights 43lbs. Sure looks like a Reed.
KMScott
Superior #3. 4" Jaws that open up to 5" and weights 45lbs. Couple pretty nice vise's Meatsis. VA own one too.
KMScott
Hollands #113. The 4" jaws opens to over 7" and weights 56lbs. Swivels from under the bench.
KMScott
Hollands 24. 4" swivel vise that opens to 8" and weights 60lbs.
KMScott
Hollands #106. 5" jaws that open to 5-1/2" and weights 110lbs. Comes with pipe jaws. Swivel releases from under the bench.
KMScott
Hollands E 3-1/2 Combination vise. 3-1/2" jaws opens to 4-1/2". No weight yet.
KMScott
Hollands 12-1/2. 2-1/2" Jaws that opens to 3" and weights 13lbs. Might be buying this one so I will add spec:s later.
edit... I did purchase it and went through a restoration on it, the jaws were cast in place so I removed them and created a new set.
KMScott
Wilton Americana 3-1/2 and 4-1/2 open screw vise's. Says made in the USA.
KMScott
Craftsman 5180. 3-1/2 inch jaws that opens over 6" and weights 30lbs.
KMScott
Chas Parker 953-1/2. 3-1/2" Jaws that opens to 5-1/2 inches and weights 35lbs.
KMScott
Yost 202-1/2. 2-1/2" jaws that open to 3-1/2" and weights 20lbs.
KMScott
Karas Electric Co Chicago. 2-1/2" jaws Clamp-on
KMScott
Penn 514. 4" Jaws that open to 6-1/2".
KMScott
Simplex/Ridge Tool 33CPN Combination Vise. 3-1/2" jaws that opens to 6" and weights 45lbs.
KMScott
Athol # 30. 3-1/2" jaws that open up to 4" and weights 26lbs.
KMScott
Chas Parker #23. 4-1/2" Jaws that opens to 5-1/2 and weights around 40lbs. Check out that Parker stand.
KMScott
Fortis F6. 6" jaws made in England with the quick release and adjustable gibs for the Dynamic slide play.
KMScott
Chas Parker # 808. 8" jaws that open to 12-1/2 and weights 297lbs.
trijeff
Northern Cali
wow what a monster ... the Parker 978 I had with it's pretty substantial base was also 297 lbs, so for a stationary that is a chunker for sure
Sent from my SM-G900T using Tapatalk
