Vise Info Thread
KMScott
Atlas/Rock Island 146. 3-5/8 jaws that weights 40 lbs. The swivel releases from under the bench.
Vise_Squad
KMS: I found several 1905 journal items about Reed combination vises in which number 41 was clearly visible on the vise - like the one on the left below. I included the item from March, 1905 because it has a bit more information even though no number is visible. No specs in either one.
This 1907 catalog cut of Reed Combination vises has the same drawing but the numbers run from 31 to 34. I haven't found anything about Reed #41's after that. There likely was a number change. If you have the jaw width of that #41 you posted, it might match one of these.
The earliest versions of this vise had individual hardened steel teeth, stacked in steel(?) cases to make up the pipe jaws.
Vise_Squad
An odd one seen on FB:
  • Screenshot 2025-11-17 at 08-01-05 Marketplace - ANTIQUE ANVIL VISE 18 LONG ADJUSTABLE SOLID HE...png
  • Screenshot 2025-11-17 at 08-00-43 Marketplace - ANTIQUE ANVIL VISE 18 LONG ADJUSTABLE SOLID HE...png
  • Screenshot 2025-11-17 at 08-00-04 Marketplace - ANTIQUE ANVIL VISE 18 LONG ADJUSTABLE SOLID HE...png
  • Screenshot 2025-11-17 at 07-59-32 Marketplace - ANTIQUE ANVIL VISE 18 LONG ADJUSTABLE SOLID HE...png
KMScott
Craftsman 5183. 5” jaws that opens to 7-1/2” and weights 77 lbs. this one I restored and added replaceable jaws. Original jaw inserts were cast in place.
royce
fairbanks ak
The perfect all around vise, well done Kevin
PS
The black on blue paint is sharp
Fred Knox
Nor Cal
Any thoughts on the manufacturer of this one? Periodically, I have tried to track down the manufacturer of this clamp-on vise but have been decidedly unsuccessful. It has the backward opening jaws, like a lot of Eastern European manufacturers (Gressel, Leinen, Schlegal, etc.) do. Its only identifying mark is "Germany" on the side of one jaw (see photo). It has 2" jaws, opens 1 1/4" and weighs about 2 lbs. Any ideas? Thanks.
twagler
Ottawa, Canada
Looks very similar to a one that I purchased a while back. See post above (#4129). From my research, I think it was a W. Hahn-Bremer KG (WHB) vise. Here's one of the pics:
Fred Knox
Nor Cal
Thanks @RTM and @twagler. I’ll check through those catalogs and report back. The WHB vise looks like a close cousin, so I’ll start with its earlier or later year models and see if I can find even a closer match. Many Thanks.
KMScott
Hoar Rotary Vise. Model 42 and 46
#42 has 2” jaws and weights 12lbs.
#46 has 4” jaws and weights 65 lbs.
Note from the owner.
‼️ 2" FANCY HOARS OFF-SHOT VISE ‼️
2" jaw Fancy Hoars jewelers vise based on the 1866
John Sherman Hoar offset patent design.
That "off-shot" jaw gives you more working room - simple idea, brilliant execution.
Over 150 years later and it still looks ahead of its time.
PeterPeter
Newburyport
Williamson Vise Co. Swivel body, swivel jaw, and base. 3 3/4” jaws open 4 3/4“, 17“ long, 80#. No model number visible. Note the atypical static solid base, instead of the three toe. There is also no name embossed on the side of the base casting. Similar to a previously posted unmarked double swivel posted back in 2021 with 2 3/4” jaws (last pic)
PeterPeter
Newburyport
WILLIAMSON VISE INFO
Notice that the drawing on the lower left of the catalog has "PATENT APL'D FOR" on the side of the vise.
The article about YOST purchasing the WILLIAMSON plant was from 1910.
PeterPeter: Model No. R has 3
3/4" jaws.
Thank you. First time I have seen this! I imagine the discrepancy in weight (68# vs. 80#) is due to the massive base. I wonder what the story is with that? You would think that if Williamson changed it, it would have carried over to Yost.
Well... Peck Stow and Wilcox actually had stuff made with their name on it. I just flipped through that entire catalog and I'm seeing all kinds of outsourced items. Whether or not "Arico" actually made anything remains a question. I don't see any branding on any of the stuff - just the usual generic descriptions (e.g., "kombizangen", etc.)
I may well have missed something - I didn't spend a lot of time flipping through it.
micahd1997
Do any fellow members here have any Prentiss Vise Company catalogs?
KMScott
Charles Parker #91 Quick Action Jewelers Vise. Hall design. 2” jaws that opens to 2” and weights 2-1/2 lbs.
PeterPeter
Newburyport
Seen in the wild, 4 3/4”, stationary machinist vise by Chas. Parker, series 3X. There is currently dead photobucket links on the vise that is listed.
6be8ca21df7c023198543d7641fd0019.jpeg4cd03f78680c5f33ba7c6389f880ad69.jpeg080ec7488735132c58bcfbbe329d0398.jpeg
peter, peter
micahd1997
I think most users and enthusiasts of Prentiss vises reasonably associate the company with the revolutionary feature that put them on the map - Mason Prentiss’ swivel jaw. However, like any company with hopes for long-term endurance MUST do…they diversified.
In 1886, Prentiss trademarked the words “Bull Dog” for use in the bench vise industry, and by 1891 they were advertising these solid-jaw, “Bull Dog” vises for purchase. While the earliest offerings were all stationary, Prentiss did eventually introduce a thru-bench, swivel base option in 1895 - 7 vises numbers 90 (3 ¼” jaws, 28 lbs) to 96 (6” jaws, 155lbs). As such, the swivel base, “Bull Dog” № 90 was the smallest that Prentiss ever made in this category. In 1902, Prentiss also added a massive, 7” jaw № 97 to this lineup, weighing 235 lbs. By 1911, the more popular, bench-top swivel base design had replaced the thru-bench option, and Prentiss redesigned the line accordingly.
All that to say - this № 90 is a clean representation of the smallest, thru-bench swivel base “Bull Dog” vise that Prentiss ever made. Given the support of multiple sources, it is between 115-135 years old.
KMScott
Athol #78. 2-1/2" jaws that opens to 2-3/4" and weights 9-1/2 lbs. Missing the swivel base.
CRSINMICH
Southeastern Michigan
Member dannyr posted a 45 mm Model 835 Henri Picard & Frere vice on the main vise thread - post number 95974.
This page is from their 1910 dental supply catalogue
Machoires = jaws. 45mm = 1.77 inches 60mm = 2.36 inches incassables = unbreakable
Henri Picard and Brother did have dealings in the United States. In the early 1900's they owned a mica mine in New Hampshire.
paulsomlo
Northern Colorado
Fray Mershon no. 3M "all-angle" vise, photos and specs from eBay.
jaw width........3-1/2"
jaw opening...5"
weight.............22 lbs.
Another "John R. Long" patent vise from one of the most prolific vise designers ever.
Yours, for only $10,000 - and i thought the tulip craze ended 600 years ago.
Fred Knox
Nor Cal
I think this may be a new one for the list:
Smart Brockville Blacksmith No.4 Anvil Vise (Brockville, Ontario, Canada)
My jaw width measured as 2 3/4", although some report it as 3" jaw width. Vise opens 4".
18 lbs. and about 13 1/2" in total length with jaws shut.
I could not find it in the 1885 catalogue, but that catalogue does have a similar "combined anvil and vice"
