The earliest versions of this vise had individual hardened steel teeth, stacked in steel(?) cases to make up the pipe jaws.KMS: I found several 1905 journal items about Reed combination vises in which number 41 was clearly visible on the vise - like the one on the left below. I included the item from March, 1905 because it has a bit more information even though no number is visible. No specs in either one.
This 1907 catalog cut of Reed Combination vises has the same drawing but the numbers run from 31 to 34. I haven't found anything about Reed #41's after that. There likely was a number change. If you have the jaw width of that #41 you posted, it might match one of these.
I like how the jaws can be moved to "go long" as well as be used as a spreader.An odd one seen on FB:
The perfect all around vise, well done KevinCraftsman 5183. 5” jaws that opens to 7-1/2” and weights 77 lbs. this one I restored and added replaceable jaws. Original jaw inserts were cast in place.
weights 78 lbs.
Looks very similar to a one that I purchased a while back. See post above (#4129). From my research, I think it was a W. Hahn-Bremer KG (WHB) vise. Here's one of the pics:Any thoughts on the manufacturer of this one? Periodically, I have tried to track down the manufacturer of this clamp-on vise but have been decidedly unsuccessful. It has the backward opening jaws, like a lot of Eastern European manufacturers (Gressel, Leinen, Schlegal, etc.) do. Its only identifying mark is "Germany" on the side of one jaw (see photo). It has 2" jaws, opens 1 1/4" and weighs about 2 lbs. Any ideas? Thanks.
This is my vise, I never see them for sale and plan to put it up on eBay.Gesswein SWIV-BALL SB-1 Toolmaker Vise. No spec:s. Made in USA.
I never had this vise when I was building Plastic Injection molds but sure used their polishing stones.
Thank you. First time I have seen this! I imagine the discrepancy in weight (68# vs. 80#) is due to the massive base. I wonder what the story is with that? You would think that if Williamson changed it, it would have carried over to Yost.Notice that the drawing on the lower left of the catalog has "PATENT APL'D FOR" on the side of the vise.
The article about YOST purchasing the WILLIAMSON plant was from 1910.
PeterPeter: Model No. R has 3 3/4" jaws.
^ Looks like "Arico" was a wholesaler/distributor, not a manufacturer. Everything from soup to nuts in that catalog.
Yours, for only $10,000 - and i thought the tulip craze ended 600 years ago.
