Vise Info Thread
KMScott
Chas Parker 654-1/2. 3-1/2" jaws that opens to 7".
KMScott
Erie 0C Combination vise. 3" jaws and weights 23lbs. Swivel releases from under the bench.
trijeff
Northern Cali
Wow, didn't even know they made a 00 ... that has gotta be one of the smallest machinists combos made. Very cool!!
Sent from my SM-G900T using Tapatalk
KMScott
Yes guys that vise is a vise you do not see every day. First one I ever seen. Would love to restore that one if the jaws were trash. Check out this next one. Todd from the Tool Archives might be interested in this one.
KMScott
Peter Wright Vise. 7" jaws that opens to 12" (I am told but might question it) and weights 176lbs. Not just an anvil maker was Peter Wright.
KMScott
Reed 108R. 8" jaws that opens to 12" and weights 260lbs
KMScott
Desmond Stephens/Simplex 61CP. 6" jaws. No other spec:s.
autopts
Kevin, I ran into a near perfect Simplex 61 CP It's upside down but son as I turn it over, I'll give you the specs. I did weigh the static and dynamic separately as I struggled to get them out of the trunk, The static with base was 83 and the dynamic was 71. I'll send you more photos when I can get it sitting straight.This photos were before I wanted to take off the base nut.
KMScott
Hollands 622 Swivel Jaw. 3-1/2" jaws.
KMScott
Sterling 28. 5" jaws that opens to 7" and weights 52lbs.
A note from a GJ Member mentions.
I believe your vise is a 100ish yr. old "un-branded" no. 28, manufactured by the Fulton Machine and Vise Co. I also think that the Sterling and Peerless models are the same as well.
akasrick
south jersey
Kevin would you add one For the Record?
Leavens Mfg. "Jersey Vise", Number 53, Baker patent Vise #877,695 -
3" jaws, opens 3" weight 8lbs. 9ozs.
A "3" is visible on the anvil with the weight would make it a No.53
Advertised as having a Brown Japanned finish.
https://www.garagejournal.com/forum/showpost.php?p=7292937&postcount=64931
Whoops looks like big picture
A 1" piece of Tiger Claw (Insulation Support) should fit the bill for a new pin.
A year & 3/4 later the pin it was bought with reinstalled. :)
https://www.garagejournal.com/forum/attachment.php?attachmentid=791164&stc=1&d=1531840612
Thanks,
akasrick
KMScott
Sure Grip. 4" anvil vise with adjustable jaws that opens to 10" and weights 40lbs. Owner notes that a date of 1899 is stamped. Might be a patent number.
KMScott
Erie # 70. 7" jaws that opens to 11-1/2" and will add the weight once the owner weights it. The swivel base lock is unique.
KMScott
Hollands Model B. 2-1/4" jaws that opens to 3" and weights ??? Oval slide vise.
KMScott
Chas Parker 954-1/2. 4-1/2" Jaws that opens to 7" and weights 63lbs. I restored this one.
KMScott
Hollands 23-1/2. 3-1/2" jaws that opens to 6" and weights 40 lbs. Cast in jaws that was redressed, I restored this one too.
KMScott
wow just wow on those jaws Kevin
Thanks Jeff. Got the Parker jaws and all others figured out.
Kevin, found this brochure that has that vise in it.
Thanks FMC for the brochure. You know I am finding the more I work on the Spreadsheet the more work there is to do. I am really enjoying working on it and I use it everyday. Thanks for letting me work on your creation. Kevin
KMScott
Columbian 604. 4-1/4 jaws that opens to 6-1/2 and weights 40lbs. First generation Columbian.
Note from GJ member. Fierljeppen
Thanks for your knowledge Fierljeppen and adding early catalog pages. We all appreciate it.
That's a 1st generation Columbian, probably pre-1915. I found a 1918 ad of a 2nd gen Columbian for comparison. 3rd gen was the "T" style jaws around 1925.
That's one of the oldest Columbian vises I've seen.
Fierljeppen
Thanks KMScott! Just trying to give back, when possible.
