Vise Info Thread
AngryBeaver
Lake Milton Ohio
I posted this in the main vise thread as well. I want your thoughts and opinions on this.
I’ve seen This in quite a few mid 40’s and 50’s reeds.
At first, I thought they were random stamps. Now, after seeing more than a dozen, and the dates lining up with when reed made changes to the spindles and whatnot, I’m 75% convinced these are date codes.
Everyone I’ve seen has been on both the static and dynamic jaw, on the left side as you are looking at the handle in front of you straight on. This is my first craftsman.
What do y’all think about this? I have 3-4 more at home I can snap pics of also. The 214R is the only one that didn’t have the stamps on the same sides.
KMScott
Beaver, you might be on to something there. I have a 1/2 dozen or more Reeds and will look and see if any of mine has stamps. Thanks for sharing.
KMScott
Hollands E4. 4" jaws that opens to 7" and weights 42lbs.
KMScott
Hollands 14-1/2. 4-1/2" jaws that opens to 6" and weights 65lbs.
KMScott
Hollands 105. 4" jaws that opens to 5" and weights 65lbs. Under the bench swivel action with pipe jaws.
KMScott
Hollands 127. 4-1/2" jaws that opens to 5" and weights 88lbs. This one missing the pipe jaws.
Fierljeppen
Prentiss 98. 322 pounds, 8-1/2" jaws, 15-1/2" height, 31" length, opens 11-1/4".
9fae1bc5f7665ff4f387df8d3dd49c89.jpg17d84df5a0498f9497f2135435db9d23.jpg441a78d28f3953455f0aad6b22a9270e.jpg5a38956c94aec3c5dfd7c7d1a0b45ce0.jpg
Happy Friday KMScott...Some catalog scans and a snippet of the Parker aquisition of Prentiss.
Have a great weekend!
KMScott
Yost 93B/93F Oval Slide vise. 3-1/4 jaws that opens to 5".
KMScott
Yost 104. 4" jaws that opens to 6" and weights 42lbs.
KMScott
Yost #31. Under the bench Combination Swivel Vise. 3-1/2 jaws that opens to 6-1/2"
KMScott
Yost 4-1/2. 4-1/2" jaws that opens to 6-1/2" and weights 60lbs.
KMScott
Dodge # 40. 4" jaws that opens to 5-1/2" and weights 55lbs.
KMScott
Prentiss 522. 3" jaws that opens to 4" and weights 58lbs.
KMScott
Prentiss #94 Bulldog. 5" jaws that opens to 7" and weights 84lbs. This guy is old. How far back was a Bulldog made? A good question. Answered by Akasarick new in 1896.
KMScott
Thanks akasrick , Prentiss used this same model number's on these earlier under the bench swiveler's and did not change the model number's with the later models swivel releasing on the side's. I'll have to think of a way to list them both.
KMScott
Oswego #1 Combination Vise. No info available. Looks like a under the bench swivel clamp release.
Fierljeppen
Hey KMScott...That's a Smith pattern that Oswego Tool made for many years. In fact, before E.W. Fulton came to town with all of his vises, Oswego Tool was making combo vises for many manufacturers, including: Parker, Walworth and Armstrong.
Check out the scans of the older and newer version of the Smith Pattern that Oswego manufactured.
Hope things work out for you and your parents. I can really empathize with what you must be going through. I've been through the same thing.
KMScott
Fierl, really good stuff. The Ontario Pattern is a new one for me, note how they used the C style jaws over the 70 degree jaws that Parker is so famous for. I wonder if Oswego had their hand in the larger Camel back combination vises for Parker and made the same jaws as Parker's. I have built a couple Parker jaws for the camel back vises and noted a difference in the shape and construction methods especially in the back angle.
Thanks for the note on my Parents. Yes it is my turn and yesterday was a big day in the Scott household. They are now both together in Assisted living. I can not get back to a normal schedule.
KMScott
Prentiss # 34 and #39. 2" Solid Jaw Jewelers Vises that both open to 2". #34 is a stationary Base and # 39 has a swivel base. Model numbers are not marked on these vises.
KMScott
Prentiss # 30 and #31. 1-3/4" Solid Jaw Stationary Jewelers Vise's that open to 1-3/4". Model #31 is the same as #30 but Nickle Plated. The model numbers are not cast in these small Jewerler's vises.
KMScott
Prentiss # 37 and #38. 2" Solid Jaw Stationary Jewelers Vise's that open to 2". Model #38 is the same as #37 but Nickle Plated. The model numbers are not cast in these small Jeweler's vises.
KMScott
Prentiss #110. 4" jaws that opens to 5-1/2" and weights 56 lbs. Built for holding bicycles. This vise is a double swivel-er like the Parker 400 series vises.
KMScott
Prentiss # 96. 6" jaws that opens to 10" and weights 155lbs. This one needs a little work but fixable.
KMScott
Reed 184-1/2 open screw vise. 4-1/2" jaws that weights around 75lbs. I noticed this vise has the split collar to adjust the backlash.
KMScott
Chas Parker 288-1/2 Combination Vise. 5" Jaws that opens to 6" and weights 118lbs.
KMScott
Prentiss/ Monarch # 403 Combination vise. 5" Jaws with pipe jaws and weights over 95lbs. Swivel releases from under the bench.
KMScott
Samson 5245 Combination vise. 4-1/2" jaws that opens to 5" and swivel releases from under the bench.
KMScott
Athol 414-1/2. Coachmakers vise with 4-1/2" jaws.
KMScott
York 125. 125 mm Jaws (4.920) that opens to 4-1/2" and weights 38lbs. One of my restorations.
KMScott
Wilton HD 4". 4" jaws that opens to 5" and weights 40lbs. This one was restored by me and a custom set of jaws was built. The 4 x 3/4 jaws that was original was welded on.
KMScott
Wilton #3. 3" jaws that opens to 7" and weights 20lbs with a date stamp of 12/46. Came with acorn nuts and when I restored this vise I built smaller swivel clamps that fit.
