Vise Info Thread
KMScott
New old stock in the box Charles Parker 973-1/2. 3-1/2" jaws that opens to 5-1/2" and weights 42lbs. Painted grey with white lettering.
MayerMR
Dallas, Texas
New old stock in the box Charles Parker 973-1/2. 4-1/2" jaws that opens to 5-1/2" and weights 42lbs. Painted grey with white lettering.
I remember reading a comment somewhere where the person said they can't remember ever seeing a vise come from the factory with already highlighted lettering. Well, I think this settles it!
wrenchguy
NW Indiana
i carefully use a rocking style blotter similar to this with good results.
MayerMR
Dallas, Texas
I just buy those enamel paint pens you can get at Michael's. They even have a little BB inside like a spray can. About a buck a piece and the fine tip makes it pretty easy.
wrenchguy
NW Indiana
yes, i use those when the lettering isn't standing very proud.:thumbup:
KMScott
I use a small brush and trim the brush hairs to only a 1/2 dozen or so and the hairs are tapered to a point, then I get comfortable and paint by hand. I do these lettering pretty fast. I cheat a little by filing the tops of the letters so they have a small flat, it helps.
wrenchguy
NW Indiana
super, i use a smallest tip sharpie too, especially on some vintage engine refurbs with the tiniest lettering u seen. i like the stiffness of the tip compared to brush flex.
Pe36nG
Here is a 8" Parker # 978 swivel base that was restored and a stand built for it from AZ. I believe a GJ member owns this. I did my little part and made a set of hard jaws for it.
very impressive c parker vise..thank for sharing
KMScott
Gambles Expert #2 Clamp on vise. 2" jaws that opens to 2-1/4".
KMScott
Colborne #16. 6" jaws and weights over 100lbs. Note the Acme 16.
KMScott
Charles Parker 1X. 3-3/4 Jaws that opens to 5-1/2" and weights 45lbs. The X was removed.
KMScott
Grand Vise Master #303. 3-1/2" jaws that opens to 4-1/2" and weights 23lbs. Has a quick release trigger.
KMScott
Charles Parker 2100. 3-1/2" jaws that opens to 4-1/4 and weights 24lbs.
KMScott
Rock Island 541B. 3-1/2" jaws that opens 6" and weights 66 lbs. This one has the pipe jaws. One of my restorations.
KMScott
VA, I really do not know, this 8" long vise is for sale in a auction at Nashua, New Hampshire. Thomas Hall of Florence, Massachusetts created the design and Patent, how C Parker came to build it is anyone guess. Neet looking vise and should go pretty high. Thanks for sharing yours, on my way to Heat treat but will see if yours is on the spreadsheet.
KMScott
Columbian 505M. 5" jaws. Older version of the M series. Note the C style jaws, not a trademark of Columbian's. Not a good idea painting everything.
DIESELMECH
Louisville, Ky
Trying to find out when this vise was made. I have read a lot of the forum on Wilton vise but I can't find the date stamp anywhere on this thing.
chrisnazzy
Arizona
No date stamps I've ever heard of on Shop Kings. I have this saved. Hope it helps. 34f44220c2956323ca003c0843f290a7.jpg
KMScott
Fulton Machine & Vise Co F M & V. 2" Rotating and Swivel Clamp-on vise that weights 7lbs.
KMScott
No Manufactures name on this one from Czech Republic but worthy of a post. 19-11/16 Jaws (50 cm) that opens to 17" (43 cm) and weights 1,830 lbs. Beats the 13" vise Royce and I built.
KMScott
Charles Parker #41, Old Swivel jaw Coachmakers vise. Thanks to Fierljeppen the jaws are 4-1/2 and opens to 9" and weights 63 lbs.
Fierljeppen
Specs for the very old Parker No.41, nice vise!
