Thanks to input from everyone here, I am the proud owner of a Wilton 1765 vise. 6.5" and 70 lbs of made in USA goodness. Now, a quick question regarding mounting this thing.
I'm sure it's a non-issue but I can't for the life of me figure out why they made the base the way they did. The holes are not symmetrical. Is there a certain direction the base is supposed to be pointing for general use, or perhaps it's to help mount in a corner somehow? Or are they just sloppy?
Check out the diagram of the holes...
One more thing... would it matter at all for stability or srength if I were to mount the vise in a way where it was typically in a diamond instead of a square? In other words, instead of mounting flat to the edge of the workbench, I would rotate it 45-degrees so one mounting hole is directly under the handle. It would help me get bolts through the bench where I need them if I mounted this way.
Thanks again for all the good advise!
