walker 882 floor jack
pakman
paragould,ar
first time post but long time reader. I have acquired a walker 882 2 ton series B floor jack as a project but is not here yet. After reading many posts, a question I have is what size socket is needed to remove the large nut holding the hydraulic unit together or is it a special tool? Thanks for any help. Paul
y'sguy
Tulsa, Oklahoma
I'm not sure which nut you are referring to, but I would think you should try using a large adjustable wrench first ala harbor freight. You could always use a cheater bar with it if necessary. All this depends on how far you need to go to get it back in shape. Mine is a Walker 884.
cubfarm 1
Be very nice to the forward nut that holds the fluid tank tight. over 400 foot pound of torque and that nut is getting hard to find
P
pakman
paragould,ar
The jack made to the house this AM. No front or top covers and lots of dirt, grease and rust. Sprayed PB blaster on it. I took photos but will have to learn how to post them. Still has faint hints of blue paint in places. Nice art deco lines.
P
pakman
paragould,ar
after some work, the front wheels now turn but the rears only swivel. the screw that holds the caster in place could it be loosened with a battery powered impact driver or a heavy duty impact sriver? Thanks
P
pakman
paragould,ar
Good afternoon,
I have worked on the jack. The rear rears now roll and turn, I am trying to get one side off to free the cylinder and my question is on the area of the front axle shaft there is a rivet that goes through the side plate and secures the axle. Since this is peened over, do you have to grind it off? Thanks all
P
pakman
paragould,ar
well I ground off the peened end of the rivrt and the front axle shaft came free but now I can not free the side from the shaft on the lower arm support of the jack . any suggestions. Thanks
