Picked up a freebie Walker 925 series D 3 ton bottle jack today. The ram moved smoothly until the seal began to leak around the handle piston. I was able to remove the spanner nut with a punch (nut was previously damaged in the same manner) and remove the deteriorated seal in pieces. What would be the correct name for the spanner needed to remove the cylinder nuts on these units? I am not going to remove the GOOD nuts in the same manner as the previously damaged one.
