Dan, that point would be what many folks conclude... But I question if HF owns a jack stand factory..
So many of the HF offerings can be found in competitor's stores with a different badge and paint scheme.. Whether they came out of the same factory, and were built to the same standards would lead to question any of them.. Whether the HF jack stands are any worse than their imported competitor's jack stands could be a **** shoot...
Harbor Freight takes this stuff seriously, and you can tell your buddy to send pictures and the story to HF corporate in Camarillo, CA.
They'll take care of him and dive into the possible causes rather quickly.
I had a set of jack stands, fail on me, I wasn't under the car at the time and I took a bunch of pictures and drove down to Camarillo and wanted an explanation from HF.
To my surprise, they were friendly and swapped out my squashed new pair, with another new pair. With a stack of 25% anything coupons and a tour of their facility.
About a few weeks later they found that there was a defect in the manufacturing process and pulled that lot from the stores.
Jason
I like the ones with the pins. They aren't going anywhere unless it breaks. I'm glad your friend is ok. Backups are a must if you're underneath a vehicle. Even if it's sliding a rim under the rocker.
I was wondering if a screw jack like this
http://www.amazon.com/dp/B00079WOZI/?tag=atomicindus08-20
Would be safer. I would like for the base to be wider.
These threads always crack me up....you have the usuals bashing HF jack stands, yet continue using other stands from almost certainly the same Chinese factory. Reality is, you can find reports of jack stands failing from a just about all manufacturers if you search long enough, and the problem isn't just inherent with HF stuff.
Regardless of the manufacturer, any stand should be routinely inspected and checked. I have several pairs of Chinese 6-ton stands, and have never felt unsafe under them. Anyone suddenly afraid of HF stands, send them to me....
I had two of these holding up the front of my F350 diesel dually for a few months, and didn't have a problem, I'm thinking this might be hit or miss..
Okay guys, talked to my friend today. (Sorry no pics)
He has lodged a complaint/concern with HF and is waiting for a reply. I will update once I hear more.
As I understand it, the "lever" that holds the shaft up is not cut straight, but on an angle. There is also the thought that the tolerance on more than one part could be off adding up to a problem. Regardless of the reason, there is too much slop in the rectangular "hole" combined with the issue on the lever.
Please understand that I'm not saying HF stuff is no good...I'm not saying all 12 ton stands are bad...just a warning to check 'em if you got 'em.
Keep in mind the lever is separate from the pawl.
Josh
I've owned 2 pair of the 6-ton HF jack stands for 15 years and have had zero issues for use on my 5,000 lb GMC K1500 truck.
However, I also don't beat them to death like jacking up the truck, placing stands underneath frame and quickly releasing the jack to let the frame slam down hard against the jack stand.
And as others have stated, I always leave the jack under the truck at near the location I'm working at as a precaution.
yeah, you're right, about 1 in 400 million have had harbor freight jack stands fail catastrophically, that's why you have never heard about it here on GJ as being a problem, because it is not a problem, or you would have heard about it!Yep, and 1 in 400,000,000 win the lottery.
No, those using logic can quickly discern that I am implying previously hearing about it here on GJ or on some news outlet, but sometimes logical thinking comes with age, and like a great bourbon, you can't rush it, it just comes with time! - eventually you will pick it up!We just did hear about it being a problem; therefore by your logic it is indeed a problem, but only to those that read this thread.
hmmmm......good point!yikes, a lot of you guys are recommending the tripod style. Ever have one of those tip on you? it is not fun.
I prefer four legs for that reason.
