Hi all:
I'm replacing a gas water heater with an electric one. The plan is to run 10/2 NM-B from a 30 amp breaker in an existing exterior-mounted panel, through 3/4" PVC conduit up the side of the two-story house into the eave, over the rafters in the attic, and then down through a hole in the sheetrock in the water heater closet on the 2nd floor. I'd planned to "hardwire" the Romex directly to the short wires coming out of the water heater inside the little door on top of the heater.
However, does NEC 2011 422.31(B) require a disconnect within reach? IF so, does this work?
Or does the little lock tab on the exterior panel count as "being locked in the open position"?
Thanks!
Thanks!
So when you need a water heater you just switch from one to the other and get it for free. Nice.
