Water heater woes again
Sh40674
Iowa
So back with another water heater question.. woke up this morning to find some water on the floor. Dripping from the relief valve/pipe. Planning on replacing the water heater as soon as we're done with some projects early summer... but is this common for them to leak? Just replace the valve and try that first? Need this thing to Last just another 2 or 3 months lol
ant.foste
Maryland
Check your incoming water pressure first. I've had two houses now that had the pressure reducing valve fail. The last house sat around 110 psi coming into the house and this current house was pushing past 140 at times.
Verify your house PSI is limited to where it should be prior to throwing parts at a symptom.
Jack_Toepfer
Lancaster NY
Valve/pipe makes me think it’s your blow off (bypass) valve? Not the drain valve?
Drain valve may just need the screw on top of it tightened.
Git
S Cal
^^^^ Good Advice
Our house has a pressure regulator that was set to around 70 psi - but one day I noticed the pressure was actually about 120 psi (there is a guage near the water heater but it is not very easy to see). If I opened a faucet, the gauge would drop to around 70 psi, but once the faucet was closed, the pressure would creep back up to 120 - which is street pressure. What happened was the regulator needed a rebuild kit (cheaper than a new one) and it's been working great ever since.
So ya, start with your water pressure
ddawg16
S. California
Yea....worth taking a look at.
Also look for a check valve. If you have an anti-siphon valve on your incoming cold water, it could prevent the pressure from being relieved on your hot water heater as the water expands from being heated up. In fact, I think there is something in the code about that. Expansion tank?
But TP valves do go bad. I've replaced mine on my 15 year old water heater. It's still working fine otherwise.....but I know a new one is in the cards for the future. If I get a couple more years out of it, I'll be quite happy.
Sh40674
Iowa
Well I replaced the valve. The old one wouldn't even let water drain when I turned it, guessing it was pretty stuck. Going to keep an eye on it for a couple days
Showkey
"MEMBER EMERITUS"
Wausau WI
sberry
Brethren, Michigan
If there is a check valve a tank is needed. I am on a well but have a gauge plumbed on to a work faucet so I can follow it. I use it a lot during irrigation and tank filling. I have troubleshot a couple problems as the well is in a remote pit, a gauge is ok there but even better i can see it every day, hour.
A gauge on city water wouldn't see the use mine does but would find a port and stick one on. Replacing a relief valve is a good idea if there is any doubt of its function, especially a stuck one.
nehog
Jaffrey, NH
1. Dripping from the TP relief valve is rarely the fault of the water heater. Check and make sure the TP valve is good, and also (important!) that there is a expansion air tank on the inlet side of the water heater. You can get the tank at HD or Lowes.
2. If you do have an expansion tank, make sure it is still good! They do fail from time to time. Also make sure the air pressure is correct in that tank.
yeldogt
They fail .... The directions say to open it occasionally to keep it clean ... they can stick and build up at the seal can make them leak.
The other possibility is the unit overheating ... but that should be easy to test.
jonshonda
Wisconsin
We bought our house last fall and I was giving the WH a once over. I tested the valve and it never stopped dripping after that. So I replaced it. It's amazing to see how much **** was built up on it.
Now I need to buy a big impact to get my anode rod out of there.
woodturner9
Indiana(ish)
In theory they should be tested monthly, but my guess is that few people do that. If you operate the valve periodically, it will remove the buildup that has started and prolong the useful life of the valve, as well as verify it will work when needed.
redmondjp
Redmond, WA
But the flip side is also true - if you do operate the valve periodically, you can also cause that very same buildup to deposit upon the sealing surface inside the valve, causing the valve to leak afterwards.
This happened at the apartment complex that I lived in during college, and it drove the maintenance technician crazy. The relief valve discharge line was shared between two heaters in separate apartments on each floor, and he had to change out one valve, wait for a week to see if the leak stopped and if not, then had to go into the second apartment and change out that relief valve.
All because somebody else said that you had to regularly test those valves.
