No such thing as
Water-Proof sheetrock, there is
water-resistant sheetrock commonly refered to as greenboard. If you need
water-proof i would suggest cement fiber board
from US Gypsum's web site:
Commonly called greenboard
SHEETROCK® Brand HUMITEK® Gypsum Panels have a non-combustible, moisture and mold resistant gypsum core that is encased in a moisture-resistant, 100 percent recycled blue face and brown back papers. The panels feature tapered long edges for easy finishing. For areas not subject to excessive moisture.
DUROCK® Brand Cement Board is ideal for use in partitions, walls, floors, soffits and ceilings in wet or dry areas. The mold- and moisture-resistant board does not deteriorate in the presence of water so it is extremely durable in baths, showers, kitchens and laundry rooms. Also suitable for exterior applications such as fences, mobile home skirting, agricultural buildings, garage wainscoting and exterior finishes; adaptable for high-heat areas such as fireplace fronts and UL-listed wall shield/floor protectors.
web site link:
http://www.usg.com/navigate.do?reso...ustom-Built_Homes-Bathrooms_area_use_page.htm
