Between 485 & 705 SQ/FT Welcome......To Odd Acres
F
Finallygotit
Tucson, AZ
For you folks following along on the journey, we have an update.
Through exhaustive investigative analysis, it has been determined conclusively that this is the primary scene (ground zero) of the serial concrete murderer, AKA Mr. Concrete.
I give you, the shed!
The slab was done in many pours, is nowhere near flat, has cracks in it out the whazoo, and some pours were so dry, I can pick out the aggregate. :sad:
sigh.............:(
More to come!
:beer:
F
Finallygotit
Tucson, AZ
So my wife and I were talking again one day after this....
And we both came to the same conclusion that it would not be advantageous to have the little car in the shop if a piece of wood decided to turn into a projectile off the table saw. What to do.......
What else could one do? Why build a new garage for the little car! And that means..............the concrete extravaganza, Odd Acres style.
Forms anyone?
And while were at it, might as well form a pad for the trailer.
Might as well tear out the dilapidated stoop in front of the shed and put in a proper unit.
More to come!
:beer:
F
Finallygotit
Tucson, AZ
And yes, it's time to pull out the pavers in front of the french doors; which my wife and I did.
And more forms......
Then we decided to put concrete in between the new garage and the shop.
More to come.
:beer:
Bib Overalls
Jonesboro, Arkansas
Use red tinted concrete for the porch in front of the French doors. A good cement finisher can cut the slab and trowel the cuts and tops to look like "pavers." Make sure your stucco walls are covered regardless of the color of the concrete you use.
-Brent-
Utah
In 2025 this thread will have a concrete skate park, a go-cart track, some cement sculptures, a helipad, and ooh, how about a parking garage, maybe a swimming pool (do they make those out of concrete anymore?), and while you're at it, pour a driveway. Haha.
Giddyup
South Australia
Dan, it has been a little while since I checked in..... what a transformation. :thumbup:
The shop and house have come along a treat. I have to say it is always good to have a sense of humor when it comes to houses... and shops...
We had a house that was built in 1959, when it came time to redo the kitchen not only were there gaps behind the cabinets for creepy crawlies (spiders) to drop in through, the gap was even big enough for four legged furries to make themselves a nest under the cabinets... :willy_nil
Keep up the good work on Odd Acres... looking forward to more adventures
jbmatth
Northern Ok.
That is just awesome, love all of the concrete and the amount of work you have put into Odd Acres. Keep posting, I'll just have to wait for more.
JB
drivesitfar
FIO: your STORY just keeps getting better and better. i too like a bit of concrete to clean up an area. so your bride gives or ok's the man cave and is ok with you building another garage? you sir are a LUCKY MAN!!
is that foundation for the new garage 10 or 12 inches thick? that is one way to keep the water from coming inside or damaging a sill plate. WELL DONE SIR!!
was there another reason for the double or triple thick foundation?
your followers comments even add a little more spice to your story so happily following along when i have time, but the push for the WEDDING is on so excuse me if i don't post as often for a while.
keep up the great work and story!!
F
Finallygotit
Tucson, AZ
OMG!! :lol_hitti I almost back flushed my nose with coffee!!!
Very impressive. I am now caught up as I read from the start.
Thank you! And thanks for stopping in.
Lets consider your build.................endorsed..:thumbup::thumbup::thumbup:
Regards
Thanks 1/2 Cup! BTW, is that a 1/2 endorsement? Now get back to that K! :thumbup:
Seriously, thank you very much!
Great job.:thumbup:
Thank you sir!
So.... are you seeing concrete in your sleep now?
Unfortunately, I am.......:sad:
Thanks for stopping by! :)
Oh there is more and thanks for the kind words! :thumbup:
JB
Thanks JB!
I keep telling her that I'm lucky but she just says I'm stuck with her. :dunno:
The pad itself is 6" thick with a 12" perimeter footer reinforced with rebar. The concrete (everywhere) is the fiber reinforced stuff. The new garage is a Tuff-Shed garage and everything about it is built like a brick outhouse. It's a bit of overkill but I like overkill.
I truly enjoy the comments and questions from other GJ members.
You sir do not need to make excuses for not posting. You have a wedding to prepare for your wonderful daughter.
Thought for this year - "I do it Daddy!"
I will try!
F
Finallygotit
Tucson, AZ
WooHoo, concrete and plenty of it .
Great stuff Dan, it looks like your guys did a good job, it'll certainly make things better around home.You don't seem to have covered it over, no threat of frost over night then. :D
Regards
Steve.
Thanks for dropping in Steve! Slowly but surely, we will have the dirt covered up. If anything green pops up from the ground, I'm going to hit it with ground clear. :evil:
What a great detailed thread. Congrats on your retirement home. Guess you wont be spending much time mowing grass in your retirement!
Thanks for the kind words Nighttrain and thanks for stopping by. :thumbup:
I didn't like mowing lawns when I was younger and I certainly don't want to do it now. Plus, with moving to this part of the country, I don't have to shovel sunshine.
Take care!
C_F
Utah...SNOW BLOWS!
Love all the new concrete around the place, those guys got it poured fast!:thumbup: I'm excited to check back in & see the progress on your new garage build.
F
Finallygotit
Tucson, AZ
OK, let's put up a garage. This new building is 16' wide by 20' deep.
All done! It took them a little over a day to get this erected and finished.
More to come!
:beer:
Bob Heine
Boca Raton, Florida
Dan, that's amazing and the white shingled roof and turbine should keep the instant garage from becoming an instant sauna. Any plan to insulate and maybe a swamp cooler?
F
Finallygotit
Tucson, AZ
So here's the little car in its new home.
The folks at Tuff-Shed made a boo-boo (in our favor) but it altered our plans for insulating the new garage. They made good and insulated the building (walls and inner roof) with rigid foam sheet, gratis. :thumbup:
So my lovely wife wanted the walls to look the same as the shop so we purchased more OSB and she went about painting them as she did before. Once this was done, it was time to epoxy coat the floor.
More to come!
:beer:
-Brent-
Utah
That radiant barrier OSB is really some awesome stuff. It was used on our shed. I'm going to use the stuff on our roofs when it's time to tear them off and reroof.
Cougar67
Virginia
I've enjoyed your build. I'd like to downsize in a few years and redo a ranch. It's interesting how buildings differ in other regions. I'm glad the Cobra got his own room. What is the power cord snaked into the trunk for? Is it a Prius engine or something? :)
Boosted1
Georgetown, KY
Wow! That was fast. Nice addition. How will you keep the hinged doors from being blown by wind into your car when driving in/out?
jbmatth
Northern Ok.
Cougar,
I would guess it is for a batter tender type charger, mine looks the exact same right now, on life support for winter.
JB
F
Finallygotit
Tucson, AZ
Hi Brent! It will be interesting to see how that stuff performs this summer.
Hello Cougar and thanks for stopping by. A Prius!?!?!?! :scared: :eyecrazy: :willy_nil Blasphemy I say!! Nothing but good ole Detroit V8 muscle in that baby. I think I need to go take a shower.
A Prius........who the heck would stick a Prius........grumble......mumble......Need shower!
Hello Boosted! I installed these SS hooks and eye's which work great to keep the doors in place.
Cougar,
JB
JB, you are correct. I have my battery installed in the trunk in a hidden compartment. Getting it in and out of there is somewhat of a pain so I plug in the battery tender whenever the car is parked to avoid having to change out the battery. Has been working quite well for years.
drivesitfar
FGI: WOW. pouring cement yesterday and parking your cool car inside an almost fully finished shed/garage/shop. just curious since that shed is pretty good size was there an option for a regular garage door?
so i think you mentioned you don't get the heat of Phoenix, but just how hot will or does it get at your place in August?
you place just keeps getting better and i bet it's almost hard to hold back your tongue on some of the comments knowing what you've already finished and haven't shown us.
KEEP UP THE GREAT STORY!!
oh and i won't mention PRIUS again. OOPS i just did!:D
speaking of batteries if you use the battery tender are you saying you need to cause you don't take your little car out often or that by plugging it in extends the life on the 5 year batteries? and how much longer do they last?
F
Finallygotit
Tucson, AZ
Hello Drives
Originally the folks at Tuff-Shed had a standard sectional door that went with this garage. I have always liked the look of barn door type garages with muscle cars lurking inside. That's why I went with the doors you see there. Plus it gives me unobstructed access to store things in the trusses.
Regarding the heat, Tucson normally sees 100° - 101° from June to August. Where we are at, we are always ~5° - 6° cooler due to our higher elevation.
And yes, I don't take the little car out as much as I would like which is why the tender is plugged in. :sad:
Bob Heine
Boca Raton, Florida
Dan, I'm hoping the battery tender will extend the life of my batteries. Not using the cars every day as well as the heat seems to kill them sooner. I was never sure the alligator clips were secure so I put pigtails on the PT Cruiser and 87 Corvette batteries so I can hook them up without opening the hood. The PT has the connector coming out the front grille and the Vette through the side vent.
sawduststeve
Havering-Atte-Bower,London/Essex boarders, England
Blimey, you don't hang about, your instant shed about as big as my garage, I do envy you your amount of space.
For what it's worth I prefer open out traditional style doors, those hooks and eyes, they're called cabin hooks here ,I must have fitted hundreds of them over time.
Great work as ever. :beer:
Regards
Steve.
Cougar67
Virginia
Der. I didn't think about your battery being relocated to the rear. I was teasing about the Prius. I use a battery Tender Jr. and only got a year from a red Optima battery. It was replaced free under warranty though. I really like those Cobras.
Grumblebum
Wollongong Australia
Hi Dan, great thread. Well written. Finished reading through in the middle of the night as one does on occasion :)
Does that mean the Quonset is now pretty much just a workshop with the replica in it's new home ? Shame about the leaks, I must admit I like that building style but after also following JB's hidey hole they seem to be heavy on the maintenance side - hopefully that sealant holds up and keeps it dry for you now.
Thanks for sharing.
Cheers GB :beer2:
1/2 Cup
Member Emeritus
Shepparton. Victoria. Australia
More to come!
:beer:
Dan, just a fantastic result, well done..:thumbup:
