Welder purchase advice? 👍
Tennessee Cattleman
East Tennessee
The best coarse of action is to figure out what Dad has in mind on the type, brand and capabilities of his future welder. Welders are to expensive to guess at.
quickfarms
Southern California
Yup, I did the LA City Structural Welding Cert class (AWS D1.1/D1.1M) about 12 years ago & all the test pieces were stick welded 1in plate. Still got my bootleg copy of the code book (because I sure as **** wasn't going to pay damn near $800 for a book I'd only need for 16 weeks).
That’s because you did the stick welding certification
FCAW is a different certification
According to one of the inspectors I know he sees far more FCAW than stick on the work he is inspecting
speed bump
Butte Montana
No, FCAW is probably the least used process of any welding professional. Structural usually sees stick welding, fabrication is usually GMAW or TIG.
You can easily do 1/4" plate in a single pass with GMAW on any decent 200+ class machine. You can do thicker with multiple passes and that holds true regardless of the process that when it comes to thick materials you're beveling the joint and doing multiple passes.
Now you are right that FCAW can have slightly better penetration and works better outdoors if there is a wind but the downside is it's messy, less easy to work with, and won't work as well on thinner materials. You can also change shielding gas mixes with GMAW to get better penetration if need be, go with a higher CO2 mix for instance.
What it sounds like to me is you have some bad personal experiences and don't really know what you're talking about. What welder is it that you own? Maybe it's just a case of you using a small 120v machine that didn't have the power needed for the materials you were working with. I personally own a Multimatic 215 and have had zero issues welding thick or thin with GMAW using C25 shielding gas.
What kind of welding do you do? Literally every contractor who shows up at our mine has at least one suitcase loaded up with flux core wire. Most of the ironworkers I know are burning wire and a decent chunk of the pipeliners are to. In the 12 years I have been in industry there has been a incredible shift towards FCAW over stick. GMAW only gets used where they do a lot of welding (and wrote a WPS for it) or you don't follow AWS D1.1 guidelines for that work. For everything else you run dual shield indoors.
All of that ignores this is for the home gamer where the welder likely won't travel and it doesn't matter. For the original question a Miller 211 setup for GMAW is ideal but I'd still keep a spool of 0.35 FCAW wire around for outside work on 110v.
ItsNemo
Canada
As with most people here, I'm a hobby guy in the garage doing fabrication on my own stuff when it comes to welding. I also have a couple little spools of flux core wire around for those odd ball things too, pretty typical.
Out in the world though, I can't think of a single time I have seen someone using flux core EXCEPT the home guy with a 120v little $200 wire glue gun. Mind you, it's been close to 15 years since I did an 8 month stint in a steel mill (doing process work, not fab/maint) or anywhere else that is heavy industry. The rest I've seen is just steel frame buildings going up, most guys running stick right off the engine driven welders.
Regardless of where flux core is used in industry though, for pretty much anyone at home it's the LAST process I'd recommend starting with. I can't actually think of a useful scenario for it other than running out of gas...I'd just throw my welding cart on my trailer, bottle and all if I had to go somewhere to do something.
IndyGarage
Indy
Well it seems you have your answer. I have a 211 as well and love it. Haven't touched my bigger machine since I got it.
I would also say the Hobart units are cheaper with fewer features but still very good. Lincoln makes good stuff too.
quickfarms
Southern California
I have been welding for over 30 years. I started at a night trade school, passing both semesters meant that I was certified to weld structural, pipeline and in nuclear power plants. I was proficient at stick and GMAW and a torch.
When I graduated stick was the king in the field and GMAW in the shop. A lot has changed since then
After graduating I bought the first small Lincoln wire feeder SP135T, in 220v, that was delivered in Southern California.
From then on my preferred method has be FCAW. Using FCAW for decades I have developed a preference for Lincoln wire.
All of my welding is done outside
Anyone who says FCAW is useless or dirty has not learned to master the process
The reasons I am not a big fan of GMAW for anything thicker than sheet metal is several fold. First GMAW requires higher amperage than FCAW. Second GMAW does not have as good a penetration as FCAW. Third you have to drag around the bottle, regulator and hose with the added expense and trips to the welding supply store. Fourth is the issues with using GMAW outside where I do all of my welding,
My frustration with GMAW is I don’t have the time to practice and can weld using FCAW without even thinking about it.
On job sites most every engine driven welder is connected to an LN25 feeding flux core wire. Stick is only used if it is just a little welding or the appropriate wire is not available.
At the shop is use a pair of lincoln 216’s in the field it is either the SP135T or the LN 25 hooked up to the SA200
ItsNemo
Canada
To be fair, that sounds like a lot of personal preference and working within your constraints, experience, and machine. Not necessarily a good recommendation for pretty much anyone else.
Besides, most home shop people aren't going to be welding beyond 1/4" plate almost ever and even a 180 amp machine can do that no problem with plenty of penetration on C25...making it a moot point about higher amperage or penetration. The cost and trips to welding store, someone would have to do the math, but factor in wire vs gas cost and then time to clean up the flux core welds afterwards...maybe a wash? Hard to say...but the dragging around a bottle and such on a welding cart, no biggy (just put bigger tires on if you drag it outside lol). Around the fourth point, yup, FCAW will work better in windy conditions (as will stick) but I agree that any self shielding process is going to be superior in those circumstances.
Bright side is, if the OP gets a Miller 211...it supports both processes :)
NUTTSGT
Northern Central Ohio
Personally, I'd prefer Blue, tan then red.
Blue is slightly out of my price range. Nothing wrong with red especially an old tombstone welder.
I had a Hobart 175, sold it and replaced it with an Ironman 230. The 230 has been replaced by Hobart with the Ironman 240. The newer 240 is an updated version .
Unfortunately, they use different spool guns if you want that option. You could check your local TSC, if have one around, to see if they have any Ironman 230 as old stock.
Boostingaz
Indiana
I can't thank everyone enough for the dialog and the suggestions and advice here. I think I am going to search for a Miller 211 for Dad. That's seems like a good "all around machine". Worst case, he doesn't like it (which won't happen), I'll just buy it from him. He is a quick study and can literally pick anything up. It's to the point where it's slightly annoying haha. He is a jack of all trades and a master of all of them! 🤣
For years he has talked about welding being the only skill he doesn't have. So between my mom and my brother, damn it, we are going to make it happen for pops!
He's retired and only still has two jobs for fun. I have never seen my Dad sit still and would be quite honestly scared to lol.
ItsNemo
Canada
LoL just wait until he picks up machining (if he hasn't already) :)
The Miller 211 (or 215, or 220) are all awesome machines and you can't go wrong with any of them or most Miller products in general. Their hoods and gloves and jackets and welding tables and a bunch of other stuff in their kit is quite nice too. The build with blue rebate that was on when I bought my machine also had a further rebate if I bought accessories so I ended up with almost a full Miller kit, quite happy that's the case.
NUTTSGT
I bought my plasma cutter from Cyberweld. Great to do business with. Check this out.
Boostingaz
Indiana
I need to see what my buddies discount actually is at the local supply house to see what I'm up against. I will definitely check this out as well. Thanks!! 🍺
quickfarms
Southern California
The blue or red debate is like ford or Chevy.
Both make good machines, and both have there own off brand, I prefer red welders and blue plasma cutters.
I would look at the local welding supply places to see what they stock consumables for, but with the internet that is not as big a deal anymore
ZRX61
Solar Blight Valley, SoCal
No, you didn't read what I said. I said "I did the structural welding cert class".. It's the class that deals with the welding code. was there some FCAW? sure, was anyone tested on it? nope.
mepstein
You're lucky in that a $2,000 budget will get you a nice red or blue machine and you don't have to listen to everyone here tell you to up your budget.
The Miller 211 is mig only but but a well liked machine and it will run on 120 and 240 volts.
The Lincoln Power Mig 210mp has just been replaced by the 215 mpi which has a couple of nice upgrades and it's still the same $1,999. It will allow you to do stick and DC tig if you find that valuable. It is also dual voltage.
As others have mentioned, by the time you get wire, gas, a cart, a helmet, gloves, etc, you're going to be into it for another $500 - $1,000.
If your dad is getting a welder for free, it may be no big deal for him to pony up for that stuff but if you want to get him everything he needs to get started, the Hobart Handler 210 MVP can be had for about $1,000 and gives you room to buy everything else within your budget.
There are others at or below that price point including some I'm not familiar with and including the Harbor freight models but again, many here would steer you toward one of the models mentioned.
Full disclosure, I have the Lincoln 210 MP.
Good luck!
I bought an MVP 2 years ago at tractor supply for $750. It looks like they go for around $1,100 now. My buddy has one as well. Very good unit. Stick with a big name so you will always have parts available.
Terra Nova
Blue is slightly out of my price range. Nothing wrong with red especially and old tombstone welder.
I had a Hobart 175, sold it and replaced it with an Ironman 230. The 230 has been replaced with the 240. Unfortunately, they use different spool guns if you want that option. You could check your local TSC, if have one around, to see if they have any Ironman 230 as old stock.
Not to derail the thread but how do you like the 240? I have a 187 handler that has been a fantastic welder but looking for something with more top end. How do you find the “run in” feature? Have read conflicting reviews with some pretty strong negative opinions of it.
MJK
Tucson, AZ
A Miller 211 is an excellent choice IMO.
If you are going to ruin the budget, get him a gas bottle of C25 and a nice helmet. He'll be ready to rip from Day 1.
Mas78
Mid-West
You'll be quite happy with the 211, When I was giving the prices earlier about the HF Migmax 215 that was more to allow you to stay in the $2k budget with everything else you'll need.
As for the flux core, most if not all are talking about the self shielded stuff. like most everyone else I have a 2lb roll of FCAW-S (self shielded) on hand incase I need to weld out in the wind. That is about the only reason I ever even want to get it out to use. Most FCAW-S wires are not rated for multipass welds but I would recommend keeping a little on hand.
I keep a 10lb roll of Lincoln FCAW-G E71-T wire that I really like to run when I have out of position welding to do on 1/4" or thicker plate.
This stuff is great, the flux freezes fast to hold the weld pool until it solidifies. I've only used 0.035" in my 211 and dad's Migmax 215. At work I use 0.045" in those welders. This wire does require shielding gas just like solid wire and I wouldn't spend the money on it right away, only if you find yourself welding vertical up and overhead on 1/4" on up plate on a regular basis.
Boostingaz
Indiana
I am going to set him up good with a nice helmet, some gloves etc etc. I want him to be ready to rip by Christmas lunch!
He's gonna get a nice welder package, and a list of my around the farm projects for Christmas hahahha.
PugetDude
Superstition Mountains, AZ
dont get anything that runs off 110v
:unsure:
My 211 will run 110 or 220. I've been welding handrails and deck panels (14-18 gauge, some heavier clips and closures) all summer at my cabin on 110v without any issues. I do have a 50' #6-50 extension cord but, don't have a 220v outlet in the garage. I run it on 220 at my house in PHX, but I honestly can't tell the difference.
Most of what I'm running is 1/8" and under, but I did run some 1/4" just to see how it did on 110V. No issues, but I didn't weld long enough for the duty cycle to become a factor.
Oh, and I'm using a #12 110V extension cord off a 20 AMP GFCI outlet (the 211 cord is #14.) Haven't popped the GFCI or the breaker yet.
Tomorrow I'm putting up my neighbors deck rails, will be tacking the stair panels together in place. I'll use my old Lincoln 135 wire feed running .035 flux core on 110v- (he has a standard outdoor GFCI outlet on the porch). then take the tacked up sections back to the shop and finish welding them up/ install the balusters with my 211 running MIG., again on 110V
So tell me again why I shouldn't bu a welder that will run on 110V?
corn chip
if i could only have one machine it would do wire and stick. your only looking at $300 more. thats a small price if you ask me
Aaron_W
I finally took a welding class in 2018, and bought a welder in 2019. I wish I had done it sooner. I don't do a ton of welding, but now having had one available, I'd hate to go back to not having one. It is such a useful skill.
If your dad will Youtube there is a youtuber Welding Tips and Tricks that is excellent. He covers a wide variety of techniques and is very easy to follow.
If you can get a deal though a local supplier that can pay off long term. I bought my welder from a local shop. They were the same price as the online shops.
They are nice guys so maybe would have treated me the same, but they know I spent $3500 on a welder and supplies with them instead of using them to figure out what I wanted and then buying online. Even though what I buy is just peanuts compared to their commercial customers I get treated like I am just as important as the guys spending thousands with them each month.
NUTTSGT
I have a 230, not 240. I guess I wasn't clear, Hobart replaced the Ironman 230 model with an updated Ironman 240.
Going back and rereading my post I see where the error was misunderstood. I'm going to fix it.
NUTTSGT
That link I provided earlier to Cyberweld, gas a promo for Miller Days, including a free helmet and I think $300 worth of Miller products .
Don't just compare welder prices, compare the entire package available.
MoonRise
Plasma cutters is grey not blue. Hypertherm, not Miller. :lol:
The old Miller 375 was a pretty much a rebadged Hypertherm. The Big-3 in welders (Miller, Lincoln, ESAB) also make or have available plasma cutters in their lines, but THE plasma cutter company IMNSHO is Hypertherm.
:beer:
Terra Nova
Gotcha, thanks. Yeah, re-reading your post that makes sense, was wondering how you wound up going from the 230 to the 240.
dnschmidt
Phoenix, AZ
:beer:
Clearly correct.
quickfarms
Southern California
Lincoln NR211MP and NR212 are both rated for multi pass
MJK
Tucson, AZ
That is awesome. Wish I could share that with my dad. Enjoy the hell out of it.
driftpin
Poking the year-old bear on this one, I have a Harbor Freight Vulcan Omnipro 220 multi-process welder I bought with my HFT class-action lawsuit payoff. I haven't used the welder much at all, but I needed some welding done on a project car, and an acquaintance we've sold car parts to, volunteered to help us. He was a bit skeptical, "I don't like Harbor Freight welders," he said before beginning to work today, but after a day of steel welding on MIG, he gave the Vulcan Omnipro 220 a solid :thumbup:He is a welder. That's his yellow car in the background, it has a GM 62.L, auto transmission, and disc brakes. Last week he was hit by a young vaping female in Orlando FL.
Some pics of the work.
Nomad engine mount weld Left.04.pngNomad engine mount weld Rt.04.pngNomad engine mount weld.03.png
