Daveyclimber
I have a 450 gallon Polypropylene slip tank used for wildland firefighting. The tank is in great shape however the top of the tank has a split at the weld. Someone had previously tried to repair using a soldering iron it appears. The repair area is several inches long. I assume the tank is likely welded inside and out on each joint except the top for obvious reasons. The material is 1/2" thick. I'm looking for the appropriate welder, techniques and consumables necessary for repair. Thanks all!.
