Vegaman_Dan
Okay, I've been reading up all I can on here on GJ and other sites to figure out what can be done about reducing blowing holes in sheet metal when trying to weld pieces. Yes, I've searched the forums. All the suggestions deal with power, speed, stickout, etc. I've applied these with very limited success.
I believe the metal of the little British car is just too thin to be welded with the equipment I have.
Hobart 120 MIG
Century 80 Flux core
Neither one of these can dial down low enough. I've tried adjusting stickout, power, speed, etc. I can do all the tests I want with the replacement sheet metal I'm using and can join that without too much work, but the original sheet metal is just blowing away and I'm left chasing holes across the surface.
It's not a rust issue that has affected the material. I've cut all of that away, formed new patch panels and can't keep them joined.
I'm wondering if this is an area where TIG really is the practical solution since you can control the heat better? I hate to spend all that money on a TIG welder as well (okay, I don't mind THAT much to have an excuse for a new tool), but since the replacement body panel is $800, I'm very much interested in saving this one.
Hobart 120 MIG
I think not.
