Welding fume extractor
dogdog
If it is at a good price and you weld a lot.. yea. probably not worth it if you are just doing welding on occasion.
It's probably just a fan and filter inside that cabinet, but those arms the good ones cost some $$$$... I remember there was one on sears website few years back on sale I wanted to get it so bad ... sub $100 clearance price. dam. anyways ...
https://www.northerntool.com/shop/tools/product_200707842_200707842
930dreamer
Amarillo,TX and Stinnett,TX
The pic shown was originally air driven but was converted to a electric motor, three types of filters, still has the air parts @ $800.
Renegade1LI
long island ny
Bought it for welding in a confined space and really worked well, you could barley tell you were welding, so far I've only changed the prefilter, I think that helps keep the expensive one clean.
lis2323
I just sold mine but it worked well
Craftfab
Garage
Lis2323, what led you to sell it?
I have been trying to decide between that Miller one and one of the ACE versions. Miller's is about 15db quieter which is nice.
lis2323
Just felt that I didn’t really need it. Not much smoke from MIG and I usually stick weld near the open door or outside.
Nethergate
Australia
I’ve been thinking about fume extraction, if I’m tig welding will it steal the argon making it useless?
bdbecker
Iowa
We've got a number of these at work. They are great if you are always welding on a table or bench and are working in the same general spot all the time. Trying to drag one around a bigger work area is annoying. Also, just be aware that a new set of filters will make your jaw drop. For a home shop, you'll probably only need to spend that money once depending on how much you weld.
If you get the intake too close, yes, that can be a problem. However, you don't need it to be right on top of where you are welding to be effective. Ideally you'd set the intake about 30-50cm above your work piece in a position so the smoke is drawn away from your head.
jhn9840
Northern Panhandle of WV
For a hobby/diy weldor, wouldn’t a well placed box fan or two along with an open window or door accomplish the same thing as a $$$$ welding fume extractor?
jhn9840
John
Nethergate
Australia
Sounds like a plan, I work in hvac so the gear to make it is free which is why I’m considering it, I wasn’t going to make it portable I was just going to put it where my fixture table lives, if I’m doing something sizeable I just open the roller doors which gives a good draft.
Im not going to stuff around with filtering I’m just going to duct the in-line fan out the roof.
Thanks for the tips guys
Cue
Zebulon, NC
I ordered the Ace and got it yesterday, tried it out last night and it worked great. It sits under my welding table. My garage is heated and cooled so I dont want to open the doors to let the heat out. I wear a respirator but after mig welding a recent project, the smoke filled the garage and I had to open the doors to clear it and let all the heat out as well, now I wont have to. I burned 4 sticks yesterday just to see how it did with stick welding as well and I could hardly smell it afterwards and there was no smoke left over. :D
lis2323
jhn9840
John
Absolutely.
