pottsie454
- Joined
- May 1, 2012
- Messages
- 61
Hey guys, I see most people that build one like posting pictures of their welding tables. Well here are some of the one I am building. Feel free to comment, I broad shoulders and can handle the criticism. Its almost complete, maybe 8 hours left plus and extra ideas you guys might come up with.
Table is 3'x8' with a half inch plate on top. I hope to upgrade to a 1inch top in the future, so I build the framework so that it will be able to support it.
I started off using the 1/2 plate sitting on 2x4 crossmembers on saw horses. I then built a border of 3 inch angle plate to support the outsite edge and still have clamping abilities. Clamped and tacked..
Then I built the table top support out of 2x4 1/8 steel tube. I can get 10 foot sticks of it for $25 a piece so I build almost everything with it..
After getting the frame work welded I started coming up with ideas for the legs. This was what I started with.
I had bought some casters with a bunch of scrap steel over the winter so I put them to use. I made 4.5"x4.5" 1/4 plates and welded nuts on the backside.
I then focused my attention to the leveling feet. Because my legs are off set 3 inches all the way around I wanted to extend the levelers out in order to make sure I had a wide base. After many failed designs, I finally found one I liked. Here is the rough idea...
Well after consideration I thought that the table would look silly with these decorative leveling legs without doing something else that would make it look cool. So I fired up the drill press and cut out 2 inch lightening holes with 2 inch thick wall pipe as filler.
Thats where I am at now. I am going to make some 12"x12" gussets to make the top frame to the legs. I will probably drill some lightening holes in them aswell. I only plan on bracing the sides and back legs together at the bottom. I want the front open to slide carts in and out for storage. I hope to bring you more pictures within the next week.
Considerations I still have to figure out... paint? Whats the strongest/best to use? and I noticed that my top frame is bowed a bit in the middle.. about a 1/16 equally from both far sides to the middle. I think I might try and stand the frame up and chain it to the floor to pull the bow out and then weld my gussest in. Think it will work? Or better ideas? I cant really shim because the plate will be held off my 3 inch angle iron defeating my purpose...
Thanks for looking!
Thanks for looking!
