Welding Table
jhelrey
MN
Would you use 1x3 rectangular tube or .5x3 flat stock for the top? I'm look at slats so I can use every day C-clamps, etc.
tarbellb
Oregon
1/2" will flex over a decent span, my 5/8" had defection with weight in the middle. Not much, but it will.
Can't remember the specs at the time, look up my name / ultimate welding table.
That said, I would still go flat bar over tube. Using the bolt method you can level the bar easier.
Walkers
Cave Creek Az
Given a choice of the materials I would pick 1x3 tubing at least 1/8” wall. So long as the table is not too big it will be okay.
As a small fabrication company, I just use solid plate, and have for about 20 years.
