With gas or not? The label is damaged and I’m not sure if I need gas or not., thanks.
B BlackdogGS Well-known member Joined Jan 28, 2012 Messages 158 Location The Dalles Oregon, Puget Island Washington Sep 14, 2020 #1 With gas or not? The label is damaged and I’m not sure if I need gas or not., thanks. Attachments 10963A4D-24C9-4E73-9BD0-9C1144BDF396.jpeg 100.3 KB · Views: 108
B bczygan Well-known member Joined Nov 4, 2009 Messages 22,002 Location DETROIT! Arsenal of Scrappers Sep 14, 2020 #2 BlackdogGS said: With gas or not? The label is damaged and I’m not sure if I need gas or not., thanks. Click to expand... See the specs on the label? AWS A5.18 and ASME SFA-5.18 Look here: https://pubs.aws.org/Download_PDFS/A5.18-A5.18M_2005PV.pdf And: http://www.weldwire.net/weld_products/ww70s-6/ With gas. GMAW Bill Last edited: Sep 14, 2020
S sberry Banned Joined Jun 18, 2005 Messages 35,747 Location Brethren, Michigan Sep 14, 2020 #3 Looks like solid, you need gas.
3 3rdgendslmech Well-known member Joined Mar 12, 2017 Messages 499 Location Maryland Sep 14, 2020 #4 If it's copper looking its most likely solid and you'll need gas. Another little trick is flux core wire will break if you bend it a couple times.
W welder4956 Well-known member Joined Apr 8, 2010 Messages 3,081 Location Birmingham, AL USA Sep 14, 2020 #5 AWS A5.18 is solid wire only, so it needs gas. Probably ER70S-6 wire, but that part of the label is missing.
G Gary Fowler New member Joined Sep 15, 2020 Messages 2 Location Unattached shop at my house Sep 15, 2020 #6 Welder 4956 is correct that it is solid wire. It does require gas. Whether it is ER70S-6 or ER70S-2 is irrelevant at this point as either is good for MIG with either C25 Ar/CO2 or straight CO2 gas.
T TractorJeff Well-known member Joined Dec 8, 2013 Messages 3,309 Location Elkhorn, WI Sep 16, 2020 #7 Its "copper" coated Mig wire probably ER-70. Use Gas!
