Well here’s a new issue...
grizzlebar
New construction house about 7 months old, installed 2 Nest thermostats on a 2 zone system (one compressor and one handler). No issues until now (at least that I’ve noticed)
So I was downstairs and walked through the main hallway which I thought was quite warm - looks like there is warm air coming out of my return intake.
Made my way upstairs to check the other one, which is drawing air in just fine and pushing it out to all the upstairs vents.
Thinking i was crazy, came back down and verified - no air is coming out of the supply vents, but it is coming out of the return intake...
Thoughts?
Done That
MO
Does the system have zone dampers in the ductwork?
All I can think is a mostly/completely blocked supply so air is "backflowing"...but i'd think it would trip a limit super fast??? Weird....
G
grizzlebar
So I’m pretty the supply/return main lines got mixed up when everything was put together. Only thing I can think of that explains full outflow at the return vent.
I guess I never noticed it before...
walta
Dutzow Missouri
If only one zone is calling for heat the system may be setup to dump any excess air pressure into the return system and some air may escape a nearby register
Walta
yeldogt
Is it variable speed --- how is the system controlling the zones?
It could have a bypass if the system has no other way to balance
G
grizzlebar
Even turning off the upper zone it still happens. My money is on crossed lines.
G
grizzlebar
nsula_country
Northwestern Louisiana
System has been commissioned and running 7 months. Wierdness recently noticed. I'd bank on a zone damper issue before assuming supply/return ducts crossed up...
Made a joke with the Nest Tstats. They are finicky at times. Like they are self aware, which they are.
Are the Nest's controlling the system? The zoning? Have a zone controller? Need more info.
CT
yeldogt
I'm assuming it's must be a 3rd party zone system. All the recent manufacturer zone controls require manufacturer specific thermostats.
OP should take some pictures of the system and look at the zone controllers to make sure they are operating
nsula_country
This is why I made the Nest statement earlier... Universal tstats and zoning don't always play nice.
CT
G
grizzlebar
AC guy came out - supply and return lines were crossed during installation
LS6 Tommy
Northern NJ
That is the only thing it can be. Changing the stat would not change airflow direction, even with malfunctioning zone dampers.
Tommy
