wera tools
Socophreak
No mine were stamped Czech republic. They are good tools. I haven't really owned any other high quality tools than these. haven't worn the tips out except for a small flat blade on an extremely tight screw.
The laser cut tip works about 10x then wears off. I have the VDE set. I probably would purchase just their regular set of screwdrivers next time. The handles feel good to me, but everybody's hands are different.
If you buy nothing but snap-on or extemely high quality tools, you probably won't be impressed. If you buy low grade craftsman sets all the time, then you will most likely be happy with them.
I would buy them again, but like I said, only regular set, not VDE. I've found I like the slimline drivers from Wiha better, and wiha goes on sale from time to time.
nanofrog
Catalog says Czech Republic, but there are some that are Taiwanese as well (Zyklops ratchets IIRC).
If you're after screwdrivers, you might do better with Wiha as already suggested. You might also want to take a look at PB Swiss (assumes you're after top end with either of these brands, though Wiha makes a couple of lines that are more affordable <hard handles & 3K series>).
zer0cell
I'd go with felo for screwdrivers. German made and good quality. Then again, the Wera Kraftform Classic was very inexpensive on amazon for me, and have held up great so far.
Nocturnal-G
Los Angeles, CA
I own a Wera Zyklop, made in Czech Republic... it's held up to all the abuse I've thrown at it. Definitely a quality tool... it's my go to ratchet in 3/8 size. The handle cleans up easily as well.
As for screwdrivers, I own Felo... quality is definitely on par with Snap On, if not better.
Stooge
South Shore, MA
i have sets of the Kraftform micro in philips and slotted and also metric hex, and Kraftform plus in philips and slotted for work, all czech, and all very high quality. have only had them for about 2 or 3 yrs now and havent had any trouble with them and dont expect to. some of the micro hex ones are starting to show some wear and rounding off a bit but thats to be expected.
is it much better than a standard swivel ratchet from snap on or mac, etc? ive been looking at them for awhile, but already have quite a few 3/8 ratchets and a 3/8 swivel from mac that i never use. from their video, it looks like it locks into place, which i like and it has a similar handle to the kraftform plus series, so its probably really comfortable
cryan
Kirkcaldy, Fife
I like their screwdrivers very much. I have never used any other Wera tool but I have been eyeing up the Joker ratchet spanner set.
Rockuf8
Northern NJ
I was seriously impressed with the Kraftorm Classic drivers I bought, they easily removed some VERY tight screws that were holding handles on my new Viper tool boxes, did a much better job than an impact driver with a diamond bit that stripped 3-4 screws that I finally gave up on, every screw I removed with the Wera philips driver came off perfectly. Coating still intact and I removed over 110 very tight screws with it.
philw
Sockets are Taiwan. I bought one from Amazon to check out the quality/style and it was marked made in Taiwan on the shipping bag.
My Wera ratchet wasn't labeled but I thought I read where they may have moved them to Taiwan also.
nanofrog
Wasn't aware of the sockets, but there was a thread on the ratchets in here somewhere (Taiwan was definitely mentioned).
Nocturnal-G
Los Angeles, CA
I actually prefer the locking point, feels better in hand. The handle is very comfortable and it's pretty smooth... cleans up easily as well.
tool-fanatic
The Zyklop is not an Taiwanese Product. I visited the german producer of the steel switcher (MIM Steel) and they explain that Wera produce the Zyklop in Cz!
Only the sockets are made in Taiwan.
allinon72
Indianapolis
I've had a set of Wera screwdrivers for a couple years now and they are good, but I don't think they live up to the craze that washed over GJ a couple years ago.
Chuck122
Québec, Canada
I cannot get over the fact that the ratchets look really gimmicky to me, but I can't argue with the fact that most people love them.
Kracin
Omaha, NE
i thought a few of their products looked "gimmicky" but im hooked on wera stuff. the chiseldrivers are my favorite screwdrivers i have ever owned, take abuse like crazy and keep going. we used chiseldrivers as a go to multi-tool at the foundry i used to work at. prybar, chisel, screwdriver, line up tool, all kinds of beating. taken them to special "j-bolts" that hold molds into pipe casting machines and had to use channellocks to turn the bolts as they were being held in place by a 3000 pound mold. and you are able to turn these bolts to free everything up, tips never broke even after throwing a ton of torque on them.
from using them to remove molten slag build up like a chisel, to being able to drive in a heli-coil and then use it as a cutoff chisel to remove any extra coil sticking out. they did it all and in an environment where steel toed boots were expected to last only 6 months or so, these screwdrivers would go 2-3 years without needing any retouching on the tips. or impact caps. only ever broke one, and standing on it to line a shaft up for a 240 chain link did the trick, but it took a **** load of effort.
i really want a set of jokers and a zyklop or two. the look of the tools makes them seem like they aren't high quality, ie, they look "styled" instead of straight forward tool look. and it can fool the eyes, but once you use some of the tools. you quickly start looking at them differently. excellent products all around.
shoturtle
Frankfurt AM
The ratchet are made in czech republic, think only the sockets are made in taiwan. When ingot my zyklops they were tade made in cz.. All the extention i have were made in cz as well as the screwdrivers and bits.
Dave455
Sussex, England
All the stuff I've seen in the U.K. has been made in the Czech Republic. I don't have a problem with that - the Czech's can turn out some decent stuff and these screwdrivers seem to be tough enough - I just wish the handles didn't look like a Daleks donger!!!
decaf
Stockholm, SWEDEN
I think a lot depends on how monitoring is from Germany.
Daleks donger...:lol_hitti
wmartin
I've got quite a few Wera items, all bought with uber-discounts or on eBay, and they seem fine.
I like them because they are cool looking.
One thing they have going for them is that they put together really good sets with cases. The Zyklops stuff has that big head to contend with, but as socket sets go I think they are nicer than Stahlwille and way way better than Felo. It's an area that the US companies still make a superior product I think.
Screwdriver-wise, I always push PB Swiss but you'll always need a beater set for cases where the driver will probably get injured or a paint can needs opening. The Wera stuff seems fine for that (along with a dozen other brands).
wmartin
The screwdrivers are excellent. Some may prefer Felo or Wiha, but those are much more expensive than Wera.
In the US, they're all roughly the same.
What you see on sites like Amazon is crazily different prices depending on how the computers there feel that day.
As an example, I have a set of Weras I threw into my main construction-guy hand carry box that cost six dollars. I also have a set of those Felo wood handled drivers that cost $15.
I get the feeling that the days of absurdly deep discounting (like the Amazon PB Swiss give-away) are pretty much gone. It's just as well, I probably only needed a couple of sets of drivers, but ended up buying any high end brands that were the cost of a music CD or a couple of cocktails.
