Very nice! The Breadboard is a nice touch. How do you like your Dewalt planer? Any issues with it?
Thanks! Breadboard ends, when done properly (as I've done), are intended to keep the top flat AND allow for natural wood movement. A far cry from those that try to accomplish the same look by simply pocket screwing a board on the end of a table (which achieves neither of those benefits).
I have the Dewalt 733, which is a nice little planer, but not what I would recommend.
I would instead recommend the Dewalt 734... the main differences are that the 734 has three knives (vs. 733 having only two) and the knives use reference pins to ensure perfect alignment each time you replace them (vs. 733 which has a spring loaded system which can be finnicky to get "just right").
Either way, these little "lunchbox" planers are built to last. I've run mine for a couple hundred hours with little other than new knives and waxing the tables now and again. Many serious woodworkers have one of these in their shop and use them frequently. Typically about $400-500 new (half that for used).
That said... if I was starting from nothing, I'd like the Dewalt 735 which is an entirely different style of machine. A bit beefier, two speeds, and it more easily handles an upgrade to Byrd Shelix cutter head if you were to ever desire that (useful for those that work with a lot of figured woods). I think these are about $500-600 new (and about half that for used). So, not a big jump in price for a big jump in capabilities.
From there, you get into stationary heavier duty planers. If you need lots of extra width, this is an option. Or, if you're milling lumber for a living, this will make sense. But, honestly, there are so many things in a shop I'd upgrade before taking this step (and believe me, I've looked into this a lot). Pricing here starts in the $1500 range and goes up and up and up.
Edit: One thing I didn't mention is that the smaller planers are loud as hell. They still capably handle whatever you throw at them, but hearing protection is a must (then... I consider hearing protection a requirement during all machine use in the shop).
Hope this helps!
